You can use Startup Applications
xrandr doesn't require sudo permissions so you can place your script in Startup Applications. Generally only use cron boot scripts for jobs requiring sudo powers.
New Script
The original answer was a reference. This new answer uses the reference and takes out unnecessary code. Then OP code is added to the bottom of the new answer.
Use sudo -H gedit /etc/cron.d/start_screen and insert these lines:
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
@reboot root /usr/local/bin/screen.sh
Save the file. There is no need to mark it as executable.
Note: The PATH command is very important as cron has limited PATH knowledge and may not find the commands such as /usr/bin/who or /usr/bin/awk.
Contents of /usr/local/bin/screen.sh
#! /bin/bash
PATH: /usr/local/bin
DESC: Set screen to brightness .5 to confirm it can be done.
Ask Ubuntu question: https://askubuntu.com/questions/1102389/xrandr-not-working-on-crontab/1102436?noredirect=1#comment1817209_1102436
CALL: called from /etc/cron.d/start-screen
DATE: Created December 17, 2018.
#!/bin/bash
export DISPLAY=:0 # For xrandr commands to work.
wait until user signs on to get .Xauthority file settings.
UserName=""
while [[ $UserName == "" ]]; do
sleep 2
logger "screen.sh slept 2 seconds waiting for login"
UserName="$(who -u | grep -F '(:0)' | head -n 1 | awk '{print $1}')"
done
sleep 30
logger "screen.sh slept 30 seconds waiting for other xrandr tasks to finish"
xhost local:root
export XAUTHORITY="/home/$UserName/.Xauthority"
xrandr --output eDP-1-1 --brightness .5
I have tested this on my machine and it works perfectly. You will want to make the following changes:
- Change
/usr/local/bin/ to /avvio/
- Remove or reduce
sleep 30. I need it because I have existing eyesome.sh cron job that sets brightness based on internet daily sunrise and sunset times for my city.
- Replace the last
xrandr line with your three xrandr lines of code
Verify results
There are logger commands in the script. This will let you see it is working by using:
$ journalctl -b -xe | grep screen.sh
Dec 17 14:25:56 alien CRON[1170]: (root) CMD ( /usr/local/bin/screen.sh)
Dec 17 14:25:58 alien root[1728]: screen.sh slept 2 seconds waiting for login
Dec 17 14:26:00 alien root[1790]: screen.sh slept 2 seconds waiting for login
Dec 17 14:26:02 alien root[1973]: screen.sh slept 2 seconds waiting for login
Dec 17 14:26:04 alien root[2070]: screen.sh slept 2 seconds waiting for login
Dec 17 14:26:06 alien root[2300]: screen.sh slept 2 seconds waiting for login
Dec 17 14:26:36 alien root[5355]: screen.sh slept 30 seconds waiting for other xrandr tasks to finish
Original Answer
Cron's @reboot option runs soon after machine is booted and before user is logged in. xrandr commands won't work until user is logged on. You can use this code from eyesome and adapt to your purposes:
SpamOn=0 # > 0 = number of times to spam in loop.
SpamCount=5 # How many times we will spam (perform short sleep)
SpamLength=2 # How long spam lasts (how many seconds to sleep)
SpamContext="" # Why are we spamming? (Login, Suspend or Lid Event)
# Future use: "DPMS Change" ie Monitor on or off.
WaitForSignOn () {
# eyesome daemon is loaded during boot. The user name is required
# for xrandr external monitor brightness and gamma control. We must
# wait until user signs on to get .Xauthority file settings.
SpamOn=10 # Causes 10 iterations of 2 second sleep
SpamContext="Login"
TotalWait=0
[[ ! -f "$CurrentBrightnessFilename" ]] && rm -f \
# Wait for user to sign on then get Xserver access for xrandr calls
UserName=""
sleep "$SpamLength"
TotalWait=$(( TotalWait + SpamLength ))
# Find UserName currently logged in.
done
log "Waited $TotalWait seconds for $UserName to login."
xhost local:root
if [[ "$fUseDbusMonitor" == true ]] ; then
echo "$UserName" > "$EyesomeUser"
sync -d "$EyesomeUser" # Flush buffer immediately
fi
} # WaitForSignOn
