I recently installed Ubuntu (18.04.1 LTS) on my old desktop to use as a server. I have been trying to manage the fan speeds, but I cannot get it to work. I started out with this tutorial: How to control fan speed?
After that didn't work I read up that dell's need some more work and tried this: Fan speed in ubuntu: pwmconfig no pwm-capable sensor modules installed
But pwmconfig still says There are no pwm-capable sensor modules installed.
And i8kctl just gives me this: 1.0 1.0 BJ17YG1 -1 -1 -1 -1 -1 -1 -1
I'm not even sure if i8k is for dell desktops, maybe only for laptops. If someone can help me out, that would be awesome, Thanks!
mo523
  • 23
I've got exactly the same problem with pwmconfig and decided to implement it on my own.
Try this utility https://github.com/ichiriac/ubuntu-smart-fan, it's based on lm-sensors and it will manage the fan speed and log them.
At start you can run it as a monitor in order to seed the fan behavior.
After calibrating the temperature and thresholds you will be able to run it as a daemon on your server, and retrieve a log with fan events
Neither of the articles you posted mentioned modifying grub, so I assume you have not done that.
You don't need i8k.
Focus on it87 in your searches. One of the common changes is to edit /etc/default/grub and append acpi_enforce_resources=lax at the end of the line GRUB_CMDLINE_LINUX. This thread confirms that it87 needs that grub change: lm sensors not returning CPU temp (it87)
rtaft
  • 1,920
