I am trying to make a rtsp server that can catch a rtsp feed from a onvif camera and then redistribute this stream to everyone that connects to my server.
I created a new Ubuntu 64-bit vm on VMware Workstation using this iso: https://www.ubuntu.com/download/desktop/thank-you?version=18.04.1&architecture=amd64
I then installed ubuntu-desktop:
$ sudo apt-get update
$ sudo apt-get install ubuntu-desktop
$ reboot
I cloned the gst-rtsp-server from its github repository to a folder on my desktop:
$ cd Desktop
$ mkdir camSrv
$ cd camSrv
$ git clone https://github.com/GStreamer/gst-rtsp-server.git
I then installed the dependency referenced by this post:
$ sudo apt-get install autoconf -y
$ sudo apt-get install automake -y
$ sudo apt-get install autopoint -y
$ sudo apt-get install libtool -y
but when i try to build the gst-rtsp-server project, I keep getting errors...
I installed a bunch of other dependencies, but now I'm stuck at the error:
configure: No package 'gstreamer-1.0' found
configure: error: no gstreamer-1.0 >= 1.15.0.1 (GSTreamer) found
I can't find what i'm missing... all i want is to make the example mentioned in this post work for me...
LoukMouk
  • 265
It seems that we do not need to compile anything by ourselves.
We can simply install required development packages from gst-rtsp-server1.0 source package :
sudo apt-get install libgstrtspserver-1.0-dev gstreamer1.0-rtsp
and then you can use it as planned.
Below is manual compilation method if you are sure that you want to do.
Install development tools:
sudo apt-get install git build-essential autoconf automake autopoint libtool pkg-config -y
sudo apt-get install gtk-doc-tools libglib2.0-dev libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev -y
sudo apt-get install checkinstall
(note libgstreamer1.0-dev above).
Clone the repository:
cd gst-rtsp-server/
But Ubuntu 18.04 LTS has old version of GStreamer library (1.14.0) so we need to checkout previous version and then compile:
git checkout 1.13.91
./autogen.sh
./configure
make
sudo checkinstall make install # enter 3 and fill *Version* field with 1.13.91
Note: you can use sudo make install in the last stage, but checkinstall is safer as it will create deb-package with compiled application (so it is controlled by APT and may be removed with sudo dpkg -r gst-rtsp).
N0rbert
  • 103,263
