On 18.10, I'm still seeing the zombie ttf-mscorefonts-installer “Failure to download extra data files” dialog every time I restart my computer.
This is a vintage bug that has been causing woe for Ubuntu users since at least 2012. I am aware of other questions and answers about this issue, but none of the solutions have worked in this case. For reference, notable prior questions are:
- "Failure to download extra data files" after installing ttf-mscorefonts-installer (2012)
- Failure to download extra data files - ttf-mscorefonts-installer (2016)
- "Failure to download extra data files" with ttf-mscorefonts-installer on Ubuntu 16.04 (2016)
Previous solutions include:
Deleting partially downloaded files
sudo rm -rf /var/lib/update-notifier/package-data-downloads/partial/
This directory does not exist on my system. There are no partially downloaded files to delete.
Sometimes an empty file is created when the failure dialog appears at:
/var/lib/update-notifier/package-data-downloads/ttf-mscorefonts-installer.failed
It does not make any difference if I delete this file or rename it to ttf-mscorefonts-installer as answers to other previous questions have suggested.
Installing a newer version from a Debian package
In the past, it was version 3.4 causing problems and users could download and install version 3.6 from a Debian repository like so:
cd /tmp
wget http://ftp.de.debian.org/debian/pool/contrib/m/msttcorefonts/ttf-mscorefonts-installer_3.6_all.deb
sudo dpkg -i /tmp/ttf-mscorefonts-installer_3.6_all.deb
# Also sometimes suggested:
sudo dpkg-reconfigure ttf-mscorefonts-installer
Later a Debian package for 3.7 became available and this method apparently worked for some users using 3.7.
The latest version available in the repositories seems to be the curiously-named 3.7ubuntu4~really3.6ubuntu3. Which appears to be “newer” than the Debian 3.7 package from the system's point of view.
I have tried installing both the system version and the 3.7 Debian package, purging previous installations beforehand, and the failure dialog still appears.
Download fonts manually
Some answers offer links to the font files contained in the package and suggest downloading them manually to the target directory. In my case, the fonts are all already there in /usr/share/fonts/truetype/msttcorefonts/. Downloading and replacing them from other sources doesn't help, the dialog still appears.
I have tried all combinations of previous solutions in all the orders I can think of and nothing solves the problem.
What else can I try to prevent this insistent dialog from appearing?
