11
I try to add a quicklaunch item to the panel in Lubuntu 18.10. This seems only to work with drag and drop from the start menu and not via a menu for the panel setting.
bomben
  • 2,167
That's correct; as of LXQt 0.13 there is no way to modify this within the LXQt Panel settings; it's mouse only.
Simon Quigley
  • 642
  • 23
Sorry, it should read like this:
[quicklaunch]
alignment=Left
apps\1\desktop=/usr/share/applications/pcmanfm-qt.desktop
apps\2\desktop=/usr/share/applications/firefox.desktop
apps\3\desktop=/usr/share/applications/qterminal.desktop
apps\size=3
type=quicklaunch
slava
  • 4,085
siggi
  • 111
This is how I did it in Lubuntu 19.04 to get the qterminal into the panel by changing the quicklaunch-section in the file "~/.config/lxqt/panel.conf":
[quicklaunch] alignment=Left
apps\size=3
> type=quicklaunch
karel
  • 122,292
  • 133
  • 301
  • 332
siggi
  • 111
Is the only way to add a quicklaunch in LXQt by mouse? (understood as drag-and-drop)
NO
What I just did in Lubuntu 20.04:
  1. Right click on the panel -> Configure panel
  2. Select Widgets
  3. Select + (Add widget)
  4. Select Quick launch. This opens a new group of quick launch icons. Select the terminal icon from the menu.
That's it. You could check the contents of ~/.config/lxqt/panel.conf, under sections [quicklaunch] and [quicklaunch2], to understand the implied changes. This is what I obtained
[quicklaunch2]
alignment=Left
apps\1\desktop=/usr/share/applications/qterminal.desktop
apps\size=1
type=quicklaunch
Manual modifications suggested in other answers are consistent with this.
