This was a known issue and has been addressed on the #ubuntu-release IRC channel.
Source: #ubuntu-release IRC logs for 2018-10-11 [Archive Link]
Shortly after this answer was originally posted, the Ubuntu package archive (http://archive.ubuntu.com/ubuntu/) was updated to fix the problem.
Note: Mirrors take a variable amount of time to synchronize with the main archive, so if you are using a mirror, you may have to wait longer or change your mirror to http://archive.ubuntu.com/ubuntu/.
Run the following command to update your package list:
sudo apt update
If your mirror is up-to-date, you should now be able upgrade all your packages, including shim and shim-signed.
Relevant IRC conversation:
[13:14] cyphermox: hi, whomever promoted shim-signed to bionic-updates, please also promote shim
  [13:14] cyphermox: (the two must go together)
  [13:29] sil2100: cyphermox: apologies for that, it didn't have a bug so my brain missed it
  [13:29] sil2100: Even though it's completely logical
  [13:29] TJ- sil2100: thanks - that'll keep a user happy. Was seeing "shim-signed" in "apt list --upgradeable" but the package wasn't offered for upgrade by apt
To prevent this same issue from happening again, ~smoser has submitted the pair of packages, shim and shim-signed, to a list that is used to verify packages that need to be released together:
[13:30] rbasak: smoser had a branch to prevent such accidents. I
  don't see what happened to it.
 [13:30] rbasak:
https://code.launchpad.net/~smoser/ubuntu-archive-tools/package-sets/+merge/348334
 [13:30] rbasak: Merged
 [13:30] cyphermox: I was
  about to ask about that, should be easy to write a warning to avoid
  this
 [13:30] rbasak: Is your ubuntu-archive-tools up to
  date sil2100?
 [13:31] rbasak: Ah
 [13:31] rbasak:
  shim and shim-signed need adding to the list.
 [13:31]
  cyphermox: yup
 [13:31] sil2100: seb128: hey! I'm going to request a full translation export and then a new base upload - I
  saw that you mentioned issues with the gnome translations, are you
  good now in case we do an export soon?
 [13:31] sil2100:
  rbasak: I thought mine was
 [13:32] cyphermox: sil2100:
  fwiw, not entirely your fault, shim didn't have any bugs linked to it
  either -- and I'm going to avoid that from now on by requiring a bug
  prior to any upload of shim to devel
 [13:33] cyphermox:
  (since we copy shim across releases, etc.)
 [13:37] seb128:
  sil2100, hey, I guess so, dunno who changed those settings but it
  screwed thing. I think I'm going to fix as much as I plan to do before
  cosmic, it's tedious work and we are not going to reupload all GNOME
  now (and import seem fine in most case, it seems the setting didn't
  change so long ago)
 [13:40] smoser: yeah, the goal of that
  branch was that it if you tried to release grub2 without grub2-signed
  it would exit failure
 [13:40] smoser: if you had > revision
  1180, i'd like to figure out what you did do that didn't trip it.  [13:42] sil2100: smoser: it was about shim and shim-signed,
  apparently that's not added to the list
 [13:42] sil2100:
  duh
 [13:42] smoser: ah. well lets add them.
 [13:42]
  smoser: if they do in fact have to be released together.
 [13:46] smoser:
https://code.launchpad.net/~smoser/ubuntu-archive-tools/shim-signed/+merge/356578
 [13:47] cyphermox: smoser: thanks
For reference, this is what the two affected package listings looked like after the fix:
Package: shim
Architecture: amd64
Version: 15+1533136590.3beb971-0ubuntu1
Priority: optional
Section: admin
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Steve Langasek <vorlon@debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 3744
Breaks: shim-signed (<< 1.33~)
Filename: pool/main/s/shim/shim_15+1533136590.3beb971-0ubuntu1_amd64.deb
MD5sum: 57145d15f6745f2dd9a081cf39da0350
SHA1: cb39bc7bddf189ab15baaf7a087169a886dc30bc
SHA256: 3099b90ba9d7bdf705a89a936b622633fe2a5141f24aa0af046b6c629d5475c5
Description: boot loader to chain-load signed boot loaders under Secure Boot
Task: ubuntu-core
Description-md5: ba97e9b3cf7ad648ef7a4f6c9fa9a6d0
Phased-Update-Percentage: 10
Supported: 5y
Package: shim-signed
Architecture: amd64
Version: 1.37~18.04.2+15+1533136590.3beb971-0ubuntu1
Built-Using: shim (= 15+1533136590.3beb971-0ubuntu1)
Priority: optional
Section: utils
Source: shim-signed (1.37~18.04.2)
Origin: Ubuntu
Maintainer: Steve Langasek <steve.langasek@ubuntu.com>
Installed-Size: 1354
Depends: debconf (>= 0.5) | debconf-2.0, shim (= 15+1533136590.3beb971-0ubuntu1), grub-efi-amd64-signed, grub2-common (>= 2.02-2ubuntu8.1), mokutil, sbsigntool
Recommends: secureboot-db
Breaks: grub-efi-amd64-signed (<< 1.93.7)
Filename: pool/main/s/shim-signed/shim-signed_1.37~18.04.2+15+1533136590.3beb971-0ubuntu1_amd64.deb
MD5sum: 5c39a5914b36861d2a4ebf318f9ac687
SHA1: 328332977616d2a2565d546e0e0dce518d8b2829
SHA256: a53e741f63a309ee9c7330386edb74905e3632ebc334386b00ab989811b2ef61
Description: Secure Boot chain-loading bootloader (Microsoft-signed binary)
Task: ubuntu-core
Description-md5: a481805ba65b750cfdd6438a7d8539a2
Phased-Update-Percentage: 20
Supported: 5y
Notice that the Depends: section of shim-signed has shim (= 15+1533136590.3beb971-0ubuntu1), which now has a matching Package: shim version.
