13
My Ctrl+Alt key combination is not recognized by my OS. My Ctrl and Alt keys both work individually. I am simply not able to use any shortcuts with Ctrl and Alt together.
I am fairly certain that something is intercepting the Ctrl+Alt command as soon as I click Alt. However, in my keyboard settings, there is nothing that uses the Ctrl+Alt hotkey. I even did a reset of all the keyboard shortcuts to be sure.
The reason why I think something is intercepting it, is that I installed some software involving switching to a Latin keyboard using the (Ctrl+Alt hotkey). And I do not know how to change this setting.
How can I fix this issue?
pomsky
  • 70,557
Luca Guarro
  • 243
This is a known issue with GNOME shell, shortcuts get triggered on-keypress instead of on-release (see this). Since you have Ctrl+Alt set to change the keyboard layout, whenever you attempt to press Ctrl+Alt+something, the shell registers only Ctrl+Alt immediately after you've pressed Alt and changes the layout.
You can disable this Ctrl+Alt combination using (GNOME) Tweaks. First install it by running
sudo apt install gnome-tweaks
and use the tool to disable the combination. Refer to this for details: Ubuntu 17.10 and later: can't change the input switching shortcut to alt+shift
pomsky
  • 70,557
I came looking for a solution to why some software I had installed (VS Code) couldn't register the input of my desired keys ( or ) as an addendum to the Ctrl+Alt sequence. The essential problem is the same, but the specifics of my fresh Ubuntu install (22.04 LTS) are different from what the accepted answer identifies as the solution.
Ubuntu's built-in settings Keyboard Shortcuts didn't list the shortcuts described, and neither did gnome-tweaks. Further searching around the topic of GNOME keyboard shortcuts led me to the question Ubuntu 17.10 and later: can't change the input switching shortcut to alt+shift, and the answers there put me on the right path:
The built-in command line interface for GNOMEs desktop key bindings is gsettings, stored under the schema org.gnome.desktop.wm.keybindings. You can list all of these as key-value pairs by running
gsettings list-recursively org.gnome.desktop.wm.keybindings
Scrolling through the list, I was able to find the following entries
org.gnome.desktop.wm.keybindings switch-to-workspace-down ['<Control><Alt>Down']
org.gnome.desktop.wm.keybindings switch-to-workspace-last ['<Super>End']
org.gnome.desktop.wm.keybindings switch-to-workspace-left ['<Super>Page_Up', '<Super><Alt>Left', '<Control><Alt>Left']
org.gnome.desktop.wm.keybindings switch-to-workspace-right ['<Super>Page_Down', '<Super><Alt>Right', '<Control><Alt>Right']
org.gnome.desktop.wm.keybindings switch-to-workspace-up ['<Control><Alt>Up']
To get rid of these bindings, I ran the following commands:
gsettings set org.gnome.desktop.wm.keybindings switch-to-workspace-down '[]'
gsettings set org.gnome.desktop.wm.keybindings switch-to-workspace-up '[]'
The change requires restarting the session by logging out & back in order to take effect.
If any mistake is made, the settings can be reverted with
gsettings reset org.gnome.desktop.wm.keybindings switch-to-workspace-down
gsettings reset org.gnome.desktop.wm.keybindings switch-to-workspace-up
Barney
  • 141
