Followup question to:
- How can I detect a duplicate version of Lubuntu installed?
- How do I remove duplicate versions of Lubuntu? (Followup)
The past couple days I have only specifically been using the 0-34 Advanced Options / Recovery Mode / Resume Normal Boot to log in, because otherwise I get locked forever in a black screen.
It's a solution I basically stumbled upon because I had tried running recovery options (and initially thought that was what helped) but one time in frustration I did 'resume normal boot' and even without running any of the recover options, it still succeeded in getting me in.
The success might have something to do with the warning I get when using Resume Normal Boot:
- some graphics drivers require a full graphical boot and so will fail when resuming from recovery
It might be the failure of a graphics driver which is saving me and letting me access the OS, if a malfunctioning driver is causing the black screen?
If I can't figure out what is causing the black screen I'd like to change the default option to Advanced > Recovery Mode to save some time until I can diagnose and correct it.
Sept 26 Update: I consulted My computer boots to a black screen, what options do I have to fix it? as David Foerster suggested.
Black/purple screen after you boot Ubuntu for the first time
This usually happens because you have an Nvidia or AMD graphics card, or a laptop with Optimus or switchable/hybrid graphics, and Ubuntu does not have the proprietary drivers installed to allow it to work with these. The solution is to boot Ubuntu once in nomodeset mode (your screen may look weird) to bypass the black screen, download and install the drivers, and then reboot to fix it for ever.
I believe this temporary "nomodeset" fix may be similar to what I've been doing with Recovery/Resume. This answer directs me to read How do I install additional drivers?
23 April 2014 Braim replied "to complete the already excellent accepted answer" with an image pertaining to Lubuntu specifics: https://i.sstatic.net/Buo87.png It says to open "System Tools" but then something called "Additional Drivers" under it. That does not display for me so I think it may have been removed from the current version.
Braim notes "after selecting Additional Drivers (or Hardware Drivers in 10.04)" but "Hardware Drivers" doesn't appear under System Tools for me either. I'm not sure what the name of the present equivalent would be for these. I did a search for both HD and AD in Synaptic Package manager couldn't find them.
Nov 11 Update, output of the terminal command lspci -nnk | awk -v n='[0300]' 'p&&/^\S/{p=0}!p{p=index($0,n)}p' requested by David Foerster
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation G72 [GeForce 7350 LE] [10de:01d0] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] G72 [GeForce 7350 LE] [1462:0563]
Kernel modules: nvidiafb, nouveau
02:00.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23418 Single-Chip MPEG-2 Encoder with Integrated Analog Video/Broadcast Audio Decoder [14f1:5b7a]
Subsystem: Hauppauge computer works Inc. CX23418 Single-Chip MPEG-2 Encoder with Integrated Analog Video/Broadcast Audio Decoder [0070:7400]
Kernel driver in use: cx18
Kernel modules: cx18
02:01.0 FireWire (IEEE 1394) [0c00]: LSI Corporation FW322/323 [TrueFire] 1394a Controller [11c1:5811] (rev 70)
Subsystem: Hewlett-Packard Company FW322/323 [TrueFire] 1394a Controller [103c:2a56]
Kernel driver in use: firewire_ohci
Kernel modules: firewire_ohci
02:04.0 Communication controller [0780]: Conexant Systems, Inc. HSF 56k Data/Fax Modem [14f1:2f20]
Subsystem: Conexant Systems, Inc. Soft Data Fax Modem with SmartCP [14f1:200c]
Sorry for delay, system wasn't connecting to internet for a few weeks, now am getting spotty reception and 2 tracker icons, not sure why, may do a sep Q about it if it persists.
I also wrote down what I can see on my monitor type if that is important:
Samson Type GH22WS
model 226 BW S
model code LS22MEWSFV/XAA
Still does the analog/digital swapping forever in normal mode so I'm still booting using the Recovery/Resume trick.
