When I boot up there are six options listed, when I think perhaps there should only be four? 1+2 and 5+6 seem to refer to different Lubuntu versions.
- Ubuntu
- Advanced options for Ubuntu
- Memory test
- Memory test serial console
- Ubuntu 18.04.1 LTS (18.04 on /dev/sd65)
- Advanced options for Ubuntu 18.04.1 LTS (18.04 on /dev/sd65)
5 and 6 appear to prompt me with a username I abandoned because I wasn't letting me do updates (some super-small partition for unknown reasons) and did a fresh install wiping out Windows Vista as well as my 1st install of Lubuntu.
This seems to be an echo of it and I want to clear up space and avoid confusion. File Manager PCManFM mentions a 3.7 GB Volume which might be the culprit.
Notes & System Info
When my computer automatically starts up, it stalls on a black screen and I'm not brought to the login screen. Choosing "Advanced" from the start-up menu and then "Recovery Mode" and then "Resume Normal Boot" seems to bring it up for me, I'm not sure where.
When I go into "Advanced" there are 4 options now (there used to be 2 yesterday!) for the normal/recovery of both 4.15.0-34 and 4.15-0.29. I chose 34 since that sounded like the more recent update. 4.15.0.29 is also the version which shows up if going into the Advanced Options for Ubuntu 18.04.1 LTS. If 29 is outdated I'd like to get rid of both 29s and just have 34 run, but have it not go into a black screen, even if that means it auto-runs Recovery Mode every time upon start-up instead of non-Recovery mode.
$ sudo lsblk -f
NAME FSTYPE LABEL UUID MOUNTPOINT
sda
└─sda1
├─LVM2_m GNFcFZ-msHQ-7StI-abZJ-sNGC-LFnZ-k0RfGA
├─lubuntu--vg-root ext4 082b416e-387c-41f5-89c2-a2346900e7e4 /
└─lubuntu--vg-swap_1 swap afc0be1d-6a95-487c-9168-eb0d410faf3e [SWAP]
sdb
├─sdb1 ntfs HP_PAVILION Adjacent Reserve 1/2 24483AB0483A809A /media/jay
├─sdb2
└─sdb5 ext4 7a6647ec-d9ef-456f-9a47-baf96238738e /media/jay
sr0
$ sudo os-prober
/dev/sdb5:Ubuntu 18.04.1 LTS (18.04):Ubuntu:linux
/boot/grub/grub.cfg:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
# GRUB lacks write support for lvm, so recordfail support is disabled.
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod lvm
insmod ext2
set root='lvmid/HORLtD-crE4-d90f-Nthf-cpUz-pHKh-jjsFCl/bHSqxy-di5E-WSMS-HeIu-XBEx-XCn3-CNMu0O'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint='lvmid/HORLtD-crE4-d90f-Nthf-cpUz-pHKh-jjsFCl/bHSqxy-di5E-WSMS-HeIu-XBEx-XCn3-CNMu0O' 082b416e-387c-41f5-89c2-a2346900e7e4
else
search --no-floppy --fs-uuid --set=root 082b416e-387c-41f5-89c2-a2346900e7e4
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_CA
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=1
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-082b416e-387c-41f5-89c2-a2346900e7e4' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod lvm
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-34-generic root=/dev/mapper/lubuntu--vg-root ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.15.0-34-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-082b416e-387c-41f5-89c2-a2346900e7e4' {
menuentry 'Ubuntu, with Linux 4.15.0-34-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-34-generic-advanced-082b416e-387c-41f5-89c2-a2346900e7e4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod lvm
insmod ext2
else
fi
echo 'Loading Linux 4.15.0-34-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Ubuntu, with Linux 4.15.0-34-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-34-generic-recovery-082b416e-387c-41f5-89c2-a2346900e7e4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod lvm
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-34-generic root=/dev/mapper/lubuntu--vg-root ro recovery nomodeset
menuentry 'Ubuntu, with Linux 4.15.0-29-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-29-generic-advanced-082b416e-387c-41f5-89c2-a2346900e7e4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod lvm
insmod ext2
else
fi
echo 'Loading Linux 4.15.0-29-generic ...'
linux /boot/vmlinuz-4.15.0-29-generic root=/dev/mapper/lubuntu--vg-root ro quiet splash $vt_handoff
initrd /boot/initrd.img-4.15.0-29-generic
menuentry 'Ubuntu, with Linux 4.15.0-29-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.15.0-29-generic-recovery-082b416e-387c-41f5-89c2-a2346900e7e4' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod lvm
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-29-generic root=/dev/mapper/lubuntu--vg-root ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod lvm
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod lvm
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Ubuntu 18.04.1 LTS (18.04) (on /dev/sdb5)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-7a6647ec-d9ef-456f-9a47-baf96238738e' {
insmod part_msdos
insmod ext2
set root='hd1,msdos5'
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos5 --hint-efi=hd1,msdos5 --hint-baremetal=ahci1,msdos5 7a6647ec-d9ef-456f-9a47-baf96238738e
else
search --no-floppy --fs-uuid --set=root 7a6647ec-d9ef-456f-9a47-baf96238738e
fi
linux /boot/vmlinuz-4.15.0-29-generic root=UUID=7a6647ec-d9ef-456f-9a47-baf96238738e ro quiet splash $vt_handoff
submenu 'Advanced options for Ubuntu 18.04.1 LTS (18.04) (on /dev/sdb5)' $menuentry_id_option 'osprober-gnulinux-advanced-7a6647ec-d9ef-456f-9a47-baf96238738e' {
menuentry 'Ubuntu (on /dev/sdb5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-29-generic--7a6647ec-d9ef-456f-9a47-baf96238738e' {
insmod part_msdos
insmod ext2
else
fi
menuentry 'Ubuntu, with Linux 4.15.0-29-generic (on /dev/sdb5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-29-generic--7a6647ec-d9ef-456f-9a47-baf96238738e' {
insmod part_msdos
insmod ext2
else
fi
menuentry 'Ubuntu, with Linux 4.15.0-29-generic (recovery mode) (on /dev/sdb5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.15.0-29-generic-root=UUID=7a6647ec-d9ef-456f-9a47-baf96238738e ro recovery nomodeset-7a6647ec-d9ef-456f-9a47-baf96238738e' {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.15.0-29-generic root=UUID=7a6647ec-d9ef-456f-9a47-baf96238738e ro recovery nomodeset
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
