I'm trying to install Ubuntu 18.04 desktop with Rufus on a computer with the following specs:
  • CPU: AMD Ryzen 5 2600
  • MOBO: ASUS Prime B450M-A/CSM
  • RAM: G-Skill Ripjaws DDR4 F4-2400C15D-16GVB
  • GPU: Nvidia GeForce GTX750
  • PSU: Apexgaming AG-650M
  • SSHD: Seagate Firecuda Compute
  • mATX: Rosewill SCM-01
Basically it boots from the USB (FAT32) and brings up a black error screen with words and numbers. Then it transitions to the purple splash screen with "ubuntu" and 5 dots, however the screen shows various visual glitches depending on which USB port I plug into.
When trying to boot the computer, it boots to a black screen with the following error message:
ACPI Error: Needed [Integer/String/Buffer], found [Region]
Here's a YouTube video that shows what I mean.
karel
  • 122,292
  • 133
  • 301
  • 332
Efefay
  • 125
Try selecting the nomodeset boot option to tell the kernel to not start video drivers until the system is up and running.
From the purple ubuntu screen press the F6 key. If you don't see this screen, shutdown, boot from the Ubuntu live USB again, and immediately after the motherboard / computer manufacturer logo splash screen appears when the computer is booting, with BIOS, quickly press and hold the Shift key, which will bring up a GNU GRUB menu screen. With UEFI press (perhaps several times) the Esc key to get to the GNU GRUB menu screen. Sometimes the manufacturer's splash screen is a part of the Windows bootloader, so when you power up the machine it goes straight to the GNU GRUB menu screen, and then pressing Shift is unnecessary.
If you see a screen that looks like the menu in the third screenshot, then scroll down to the next section (Enable nomodeset from GRUB boot menu) and follow the instructions in that section instead.
After pressing F6, press Enter on nomodeset and an "x" will appear to the left of the option. Press Esc to leave the popup menu. The selections are retained at the time the user presses the Esc key. Then use the down arrow key to highlight the Install Ubuntu option and press the Enter key to select it.
The below section is intended to be used when the menu in the first screenshot does not show when booting from the Ubuntu live USB. Otherwise follow the instructions in the first section.
Safe Graphics Mode. A new option is added to the GRUB menu in 19.04 and later which will boot with nomodeset on. This may help you resolve issues on certain graphics cards and allow you to boot and install any proprietary drivers needed by your system.
Immediately after the motherboard / computer manufacturer logo splash screen appears when the computer is booting, with BIOS, quickly press and hold the Shift key, which will bring up a GNU GRUB menu screen. With UEFI press (perhaps several times) the Esc key to get to the GNU GRUB menu screen. Sometimes the manufacturer's splash screen is a part of the Windows bootloader, so when you power up the machine it goes straight to the GNU GRUB menu screen, and then pressing Shift is unnecessary.
You will see a GNU GRUB menu screen that looks like this:
Press e to enter editing mode. This will bring up a GNU GRUB screen that looks like this:
Use the arrow keys to navigate when screen editing the above screen. Navigate to after the string on this screen that starts with root=. In this example screen the full string is root= followed by UUID= and a hexadecimal string as shown below:
root=UUID=bcf15ef2-a0b2-4753-9558-8399dd12a729
Immediately after this string replace ro quiet splash by nomodeset quiet splash. This change is only temporary — it will just be used once and GRUB won’t remember it in the future. Press Ctrl+X or F10 to boot with the nomodeset option that was added. If you make a mistake, press Esc to go back to the previous screen.
To make the change permanent you need to add it to the /etc/default/grub file. Append nmodeset inside the quotes of the line GRUB_CMDLINE_LINUX_DEFAULT="...". Then update your grub settings with sudo update-grub.
karel
  • 122,292
  • 133
  • 301
  • 332
I just ran into this same issue upgrading my pc with new CPU, Motherboard, GPU and Ram.
Ryzen 7 7200X CPU Tuf B450 Motherboard EVGA 1660 Super
I ended up having to take out the 1660 and put my old GPU EVGA 970 in to get a display, and then downloaded the 1660 drivers from EVGA. After I did that I was able to reinstall the 1660 and reboot with success. Everything seems to be running smoothly now.
Shane
