So, for a first time try with a USB boot drive, i used the recommended Ubuntu 12.04.3 version. After using the pen drive Linux USB installer to install Ubuntu onto it, I restarted my PC and changed the boot priorities in the BIOS so that it boots from the USB first, however after many attempts my PC just boots straight into win 8. The board I have is the ASUS M4A79XTD Evo (AM3). Any help will be much appreciated, thanks
I would first double check whether your boot loader really starts reading from USB device. Then try the USB on other computer (with correct boot priority of course).
It also might be that the USB has not been correctly written.
If the USB is able to boot your other PC, so perhaps 12.04 misses some of your goal PC drviers. In this case using a 13.04 image can resolve the problem.
- 1,357
What i would do, is format the USB as FAT32, then use the Linux USB installer again. please reply if it worked. If that doesn't work perhaps try a Live CD?
- 156
- 1
- 2
- 9
Had the same problem for booting off a live disc on a toshiba laptop with a preloaded Windows 8 OS. Since you know how to enter your bios to change your boot order I would recommend checking a few other important settings first.
Have you disabled 'Fast Startup' in Windows. (admin rights)
Enter 'Control Panel'. Click/Search 'Power Options'. On the left side panel click 'Choose what the power buttons do'. Click 'Change settings that are currently unavailable' that is located at the top. Near the bottom of the next page uncheck 'Turn on fast startup (recommended)'
Have you disabled 'Secure Boot' and 'UEFI' mode in your bios.
Enter your bios and navigate to the 'Security' section - make sure 'Secure Boot' is disabled. Navigate to the 'Advanced' section in your bios and make sure your 'Boot Mode' is 'Legacy' NOT 'UEFI' - if 'Boot Mode' is not visible under 'Advanced' look for it under 'System Configuration'.
To change everything back to their original settings redo steps 2 and 1 in opposite order ; )
*Never prefered to use a usb installer. You are better off booting from a live dvd and partitioning the usb yourself. JUST MAKE SURE YOU SELECT THE APPROPRIATE DRIVE!!! I always used 'http://www.linuxbsdos.com/2011/05/23/install-ubuntu-11-04-on-external-hard-disk/' when installing on an external device
- 11
- 2
