Using 11.10 for the record. It would be easiest to do it on the Terminal.
You can do it as follows:
bcbc@ubuntu:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/loop0 15G 7.3G 7.0G 51% /
udev 1.9G 4.0K 1.9G 1% /dev
tmpfs 751M 920K 750M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1.9G 416K 1.9G 1% /run/shm
/dev/sda3 295G 113G 183G 39% /host
bcbc@ubuntu:~$
This shows that the Wubi virtual disk is mounted as / on /dev/loop0 and is 15G in size with 7G free. If you had more thane one virtual disk you'd see perhaps /dev/loop1 mounted on /home.
It also shows that the Windows /host is 295G in size and has 183G free.
What to do if you're short on space
- Clean up cache
- Use
baobabto check where your space is gone - Remove all but the most recent 2 working kernels
- Resize the virtual disk
- Migrate to a partition
1. Clean up cache
sudo apt-get autoremove
sudo apt-get autoclean
2. Use the disk usage analyzer
From a command line run: gksu baobab
Make sure you go to Edit, Preferences and uncheck the Windows /host partition before scanning the file system or it will scan your Windows /host as well.
3. Remove old kernels There are various ways to do this. Just make sure you keep the two most recent working kernels. Each kernel can free up about 190MB.
Here's one method to do this (via Kees Cook):
OLD=$(ls -tr /boot/vmlinuz-* | head -n -2 | cut -d- -f2- | awk '{print "linux-image-" $0}')
if [ -n "$OLD" ]; then sudo apt-get -q remove --purge $OLD; fi
That's probably better in a script, but if you enter each line, it does the trick. You can use synaptic package manager for this, but I understand this isn't installed by default anymore.
4. Resize a Wubi install You can do an in-place resize of the virtual disk Wubi uses or make a new, larger disk. The former must be run from a live CD and is quickest, but the latter can be done from a running Wubi install.
5. Migrate a Wubi install See how-to-convert-wubi-install-into-regular-install
