My Ubuntu partition was working on 50gb . However, even-though I had not used much of the memory, I was still getting messages saying the disk space is low. I increased the partition, but am still getting that error. I hardly have any bulky programs or anything like that installed. Where did the disk space go? Can someone please have a look and tell me what is happening?
Filesystem      Size  Used Avail Use% Mounted on
/dev/loop0       19G   17G  1.6G  92% /
udev            982M  4.0K  982M   1% /dev
tmpfs           396M  1.2M  395M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            990M  384K  989M   1% /run/shm
none            100M   36K  100M   1% /run/user
/dev/sda3       138G   25G  114G  18% /host
berkes
  • 1,617
You can use the Disk Usage Analyzer, baobab in 12.04, to see where the disk usage has gone. If you are using the command line only, there's a number of ways to find the largest directory in Linux
Thinks you can keep an eye on include:
  • Log files (/var/log)
  • apt cache (/var/cache/apt/archives)
AJefferiss
  • 1,154
  • 17
