I'm new to Ubuntu and I've 18.04 installed. Not sure if this is due to faulty installation or something, but I'm having trouble with very slow Wi-Fi speeds and frequent disconnections. Here is a pastebin link to diagnose my issue, important info as follows:
##### kernel ############################
Linux 4.15.0-33-generic #36-Ubuntu SMP Wed Aug 15 16:00:05 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=1
##### lspci #############################
08:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
    Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter [103c:804c]
    Kernel driver in use: rtl8723be
09:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 0a)
    Subsystem: Hewlett-Packard Company RTL810xE PCI Express Fast Ethernet controller [103c:8096]
    Kernel driver in use: r8169
Any help is greatly appreciated. I've started a new project in college and need to use Ubuntu. If it helps, I'm using a HP Pavilion Notebook (M2W75PA#ACJ).
So far, I tried disabling 802.1n band. Unfortunately, it didn't help me much.
pomsky
  • 70,557
In your pastebin, we see this:
[/etc/modprobe.d/rtl8723de.conf]
options rtl8723de ant_sel=1
You haven’t any rtl8723de device; yours is an rtl8723be. They are two different devices. Let’s remove the needless file:
sudo rm /etc/modprobe.d/rtl8723de.conf
We also see this:
[/etc/modprobe.d/rtl8723be.conf]
options rtl8723be ant_sel=2
options rtl8723be 11n_disable=1
11n_disable is not an available parameter in the driver rtl8723be. Confirm:
modinfo rtl8723be
Let’s remove the needless declaration:
sudo nano /etc/modprobe.d/rtl8723be.conf
Remove the 11n line so that the file now only contains:
Save (Ctrl+o followed by Enter) and close (Ctrl+x) the text editor.
We also see:
Cell 01 - Address: <MAC '301 Th' [AC1]>
                    Channel:9
                    Frequency:2.452 GHz (Channel 9)
                    Quality=54/70  Signal level=-56 dBm
                    Encryption key:on
                    ESSID:"301 Th"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=00000000c8e6d93d
                    Extra: Last beacon: 60ms ago
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
I have worked on several cases where removing a space in the name of the SSID improved connectivity. If this is a router for which you have administrative privileges, I suhhest that you rename it to 301Th or 301_Th or some such without a space.
Next, check the settings in the router. WPA2-AES is preferred; not any WPA and WPA2 mixed mode and certainly not TKIP. Second, if your router is capable of N speeds, you may have better connectivity with a channel width of 20 MHz in the 2.4 GHz band instead of automatic 20/40 MHz, although it is likely to affect N speeds. I also have better luck with a fixed channel, either 1, 6 or 11, rather than automatic channel selection. Also, be certain the router is not set to use N speeds only; auto B, G and N is preferred. After making these changes, reboot the router.
Please see this interesting post about the unreliability of auto channel select: https://superuser.com/questions/1311149/why-do-wifi-routers-do-such-a-bad-job-of-channel-selection
Next, I recommend that your regulatory domain be set explicitly. Check yours:
sudo iw reg get
If you get 00, that is a one-size-maybe-fits-all setting. Find yours here: http://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 Then set it temporarily:
sudo iw reg set IS
Of course, substitute your country code if not Iceland. Set it permanently:
sudo nano /etc/default/crda
Change the last line to read:
REGDOMAIN=IS
Proofread carefully, save and close the text editor.
chili555
  • 61,330
