Yesterday, I updated my HP Laptop from Ubuntu 17.10 to 18.04.
Since then, the WiFi signal is very weak. I have tried all the options with downloading new driver from git. And tried with both ant_sel=1 and ant_sel=2 but both gives weak signal. In 17.10 ant_sel=2 used to work.
Any idea on what would have went wrong during the update?
Output of iwconfig:
enp2s0 no wireless extensions.
lo no wireless extensions.
wlo1 IEEE 802.11 ESSID:"Sniper"
Mode:Managed Frequency:2.437 GHz Access Point: 94:65:2D:02:E3:91
Bit Rate=72.2 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:off
Link Quality=34/70 Signal level=-76 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:159 Missed beacon:0
siddharth@siddharth-HP-Notebook:~$ iwlist scan | egrep -i 'ssid|quality'
enp2s0 Interface doesn't support scanning.
lo Interface doesn't support scanning.
Quality=32/70 Signal level=-78 dBm
ESSID:"Sniper"
This is when I sit next to the modem.
I have done the below steps:
- Cloned latest rtlwifi_new from git
makesudo make installsudo modprobe -rv rtl8723besudo modprobe -v rtl8723be ant_sel=2sudo ip link set wlo1 upsudo iw dev wlp13s0 scan
At no point I got any error. Tried with ant_sel=1 also.
Update:
Output of lshw -C network:
siddharth@siddharth-HP-Notebook:~$ lshw -C network
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 07
serial: 30:e1:71:97:de:e0
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:16 ioport:4000(size=256) memory:b1200000-b1200fff memory:b1000000-b1003fff
*-network
description: Wireless interface
product: RTL8723BE PCIe Wireless Network Adapter
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlo1
version: 00
serial: 58:00:e3:a7:14:cb
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8723be driverversion=4.15.0-33-generic firmware=N/A ip=192.168.43.59 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:17 ioport:3000(size=256) memory:b1100000-b1103fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user
