14
My Wi-Fi is slow or completely broken when using Bluetooth headphones. It is said that this is a well know issue, as Bluetooth and Wi-Fi share the 2.4GHz frequency.
Is this something that could be solved? Are cheap/low-end devices more problematic than quality ones?
What I Have Tried
  1. Disable coexistence in iwlwifi, as suggested by Pilot6, by running the following command and rebooting:
    sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi bt_coex_active=N"
    This was only a slight improvement, as it changed the speed of Wi-Fi from zero to unusably slow.
  2. Try different channels on router.
    I tried both ends of the spectrum (1 and 11), neither created any improvement. Wi-Fi still broken as soon as headphones are turned on. Setting router channel to auto has the best results so far.
System Info
$ uname -a
Linux alien-box 4.15.0-29-lowlatency #31-Ubuntu SMP PREEMPT Tue Jul 17 17:49:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ lspci -knn | grep Net -A3; lsusb 04:00.0 Network controller [0280]: Intel Corporation Wireless 7265 [8086:095a] (rev 59) Subsystem: Intel Corporation Dual Band Wireless-AC 7265 [8086:5410] Kernel driver in use: iwlwifi Kernel modules: iwlwifi Bus 002 Device 002: ID 8087:8000 Intel Corp. Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:8008 Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 006: ID 1058:07a8 Western Digital Technologies, Inc. My Passport (WDBBEP), My Passport for Mac (WDBLUZ) Bus 004 Device 005: ID 0bc2:ab31 Seagate RSS LLC Backup Plus Desktop Drive (5TB) Bus 004 Device 004: ID 2109:0812 VIA Labs, Inc. VL812 Hub Bus 004 Device 003: ID 2109:0812 VIA Labs, Inc. VL812 Hub Bus 004 Device 002: ID 2109:0812 VIA Labs, Inc. VL812 Hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 005: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec Bus 003 Device 004: ID 28de:1142
Bus 003 Device 003: ID 8087:0a2a Intel Corp. Bus 003 Device 002: ID 062a:4101 Creative Labs Wireless Keyboard/Mouse Bus 003 Device 010: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 003 Device 009: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 003 Device 008: ID 05e3:0727 Genesys Logic, Inc. microSD Reader/Writer Bus 003 Device 007: ID 0b33:0020 Contour Design, Inc. ShuttleXpress Bus 003 Device 006: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 003 Device 011: ID 0d8c:0012 C-Media Electronics, Inc. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ lsmod |grep 'bt|blue|rfcomm|bn' rfcomm 77824 4 bnep 20480 2 btusb 45056 0 btrtl 16384 1 btusb btbcm 16384 1 btusb btintel 16384 1 btusb bluetooth 548864 33 btrtl,btintel,bnep,btbcm,rfcomm,btusb ecdh_generic 24576 2 bluetooth
Bluetooth works on the same 2.4 GHz freq as Wi-Fi.
BT coexistence is bad in iwlwifi, but enabled by default.
Run
and reboot.
Pilot6
  • 92,041
-1
This solution worked for me (using Qualcomm Atheros module):
echo "options ath9k btcoex_enable=1"  >  /etc/modprobe.d/ath9k.conf
see details: WiFi and Bluetooth coexistence: Qualcomm Atheros ar9462: Ubuntu 16.04
