How can I install clang on Ubuntu 18.04 LTS Bionic?
clang-6.0 is (at least currently) the default version of clang on Bionic:
$ apt-cache depends clang
clang
Depends: clang-6.0
Breaks: <clang-3.2>
Breaks: <clang-3.3>
Breaks: <clang-3.4>
Breaks: <clang-3.5>
Replaces: clang
Replaces: <clang-3.2>
Replaces: <clang-3.3>
Replaces: <clang-3.4>
Replaces: <clang-3.5>
$ apt-cache policy clang-6.0
clang-6.0:
Installed: 1:6.0-1ubuntu2
Candidate: 1:6.0-1ubuntu2
Version table:
*** 1:6.0-1ubuntu2 500
500 http://ca.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
100 /var/lib/dpkg/status
So, you just enable the universe repository and then install clang - either from the software store or from the command line using
sudo apt update
sudo apt install clang
- 142,475
Adding to @steeldriver's answer, clang is a dependency package providing the default clang version, which is 6.0 in Bionic.
You may have better luck installing the clang-6.0 package directly:
sudo apt-get update
sudo apt-get install clang-6.0
- 2,025
You can install clang-6.0 on Ubuntu 18.04 using official LLVM repository.
wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
sudo apt-add-repository "deb http://apt.llvm.org/bionic/ llvm-toolchain-bionic-6.0 main"
sudo apt update && sudo apt install clang-6.0
- 19,753
You might be missing some necessary channels from sources.list.
Step 1: Backup your repositories and remove repository lists other than sources.list.
Step 2: Do sudo gedit /etc/apt/sources.list and make it look like this:
deb http://archive.ubuntu.com/ubuntu bionic main multiverse restricted universe
deb http://archive.ubuntu.com/ubuntu bionic-security main multiverse restricted universe
deb http://archive.ubuntu.com/ubuntu bionic-updates main multiverse restricted universe
Save and exit.
Step 3: Update your repository:
sudo apt update
Step 4: Install clang-6.0:
- 7,522
You can do as users above shared
just that i want to pay your attention to this interesting document : LLVM Debian/Ubuntu nightly packages
to get a complete vision how to install nightly packages.
- 113
Actualize by latest versions of the compiler:
sudo apt-get update
# sudo apt-get install clang-9
sudo apt-get install clang-10
- 103
- 4
