I tried installing clang on Ubuntu 18.04, but I could not install it. I tried sudo apt install clang and got these results:
Reading package lists... Done
Building dependency tree
 clang : Depends: clang-6.0 (>= 6.0~) but it is not going to be installed
I read some answers about held packages and tried sudo aptitude install clang, but it also didn't work.
I got the following results:
The following NEW packages will be installed:
  clang-6.0 lib32gcc1{ab} lib32stdc++6{ab} libc6-i386{a} libclang-common-6.0-dev{a} libclang1-6.0{a} libffi-dev{a} libjsoncpp1{a} libobjc-7-dev{ab} libobjc4{ab} libpython-stdlib{a} libtinfo-dev{ab}
  llvm-6.0{a} llvm-6.0-dev{a} llvm-6.0-runtime{a} python{a} python-minimal{a} python2.7{ab} python2.7-minimal{ab}
0 packages upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
Need to get 53.4 MB of archives. After unpacking 313 MB will be used.
 lib32stdc++6 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04 is installed
 libobjc4 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04 is installed
 python2.7-minimal : Depends: libpython2.7-minimal (= 2.7.15~rc1-1) but 2.7.15~rc1-1ubuntu0.1 is installed
 python2.7 : Depends: libpython2.7-stdlib (= 2.7.15~rc1-1) but 2.7.15~rc1-1ubuntu0.1 is installed
 lib32gcc1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.3.0-6ubuntu1~18.04 is installed
 libobjc-7-dev : Depends: gcc-7-base (= 7.3.0-16ubuntu3) but 7.4.0-1ubuntu1~18.04 is installed
                 Depends: libgcc-7-dev (= 7.3.0-16ubuntu3) but 7.4.0-1ubuntu1~18.04 is installed
 libtinfo-dev : Depends: libtinfo5 (= 6.1-1ubuntu1) but 6.1-1ubuntu1.18.04 is installed
The following actions will resolve these dependencies:
      Keep the following packages at their current version:
1)      clang-6.0 [Not Installed]
2)      lib32gcc1 [Not Installed]
3)      lib32stdc++6 [Not Installed]
4)      libclang-common-6.0-dev [Not Installed]
5)      libobjc-7-dev [Not Installed]
6)      libobjc4 [Not Installed]
7)      libtinfo-dev [Not Installed]
8)      llvm-6.0-dev [Not Installed]
9)      python [Not Installed]
10)     python-minimal [Not Installed]
11)     python2.7 [Not Installed]
12)     python2.7-minimal [Not Installed]
      Leave the following dependencies unresolved:
13)     python-minimal recommends python
14)     python2.7-minimal recommends python2.7
15)     clang-6.0 recommends python
16)     llvm-6.0 recommends llvm-6.0-dev
Accept this solution? [Y/n/q/?] y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
karel
  • 122,292
  • 133
  • 301
  • 332
Sony
  • 99
As indicated here you need to enable the bionic-updates suite in your sources.list
prepend or append the following block to your /etc/apt/sources.list
deb http://archive.ubuntu.com/ubuntu bionic main multiverse restricted universe
deb http://archive.ubuntu.com/ubuntu bionic-security main multiverse restricted universe
deb http://archive.ubuntu.com/ubuntu bionic-updates main multiverse restricted universe
#deb-src http://archive.ubuntu.com/ubuntu bionic main multiverse restricted universe
#deb-src http://archive.ubuntu.com/ubuntu bionic-security main multiverse restricted universe
#deb-src http://archive.ubuntu.com/ubuntu bionic-updates main multiverse restricted universe
uncomment the deb-src lines if you want the source code from the repositories, if you need that.
then simply run sudo apt update; sudo apt install clang and you'll be good.
FalcoGer
  • 925
