I've bought a new Seagate Expansion Portable Drive 2TB with exFat format. It works normally on Windows. On Ubuntu 18.04 I tried to mount the HD but failed.
I found advice to install exfat-fuse and exfat-utils (exfat 1.2.8). I've done that and still the HD is not mounting.
I tried to format the hd to NTFS but failed. I formatted it back with success to exFat. Still Ubuntu does not mount the HD. On disk it just mention 2TB block device. No partition.
Tried to format using mkfs.exfat but I get an Input/Output error. Checking on Windows for drive error found nothing wrong.
Zanna
  • 72,312
Just press Ctrl+Alt+t and When your terminal appears, Type below command and boom:
sudo apt-get install exfat-fuse exfat-utils
Unplug your exFat external flash and then plug it again. This way settled my issue. Hope helps you.
AmerllicA
  • 559
exfat* was missing from my list as well, and I couldn't find a reliable repo source to add:
# apt-get install ex
example-content exim4 exim4-base exim4-config exim4-daemon-heavy  exim4-daemon-light exim4-dev exim4-doc-html exuberant-ctags
I ended up downloading it from here.
Then ran dpkg -i exfat-fuse_1.2.8-1_amd64.deb to install.
Pablo Bianchi
  • 17,371
For Ubuntu 18.04 LTS please use the following command:
sudo apt-get install exfat-fuse exfat-utils --fix-missing
Nmath
  • 12,664
