I reinstalled a driver on Windows for Broadcom Network Adapter and after that my WiFi stopped working on Ubuntu(16.04) completely.
I tried to reinstall drivers, using this commands:
1. sudo apt-get purge bcmwl-kernel-source
2. sudo apt-get install bcmwl-kernel-source
But it didn't help
Output of the second command(install bcmwl-kernel-source):
Unpacking bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) ...
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) ...
Loading new bcmwl-6.30.223.271+bdcom DKMS files...
First Installation: checking all kernels...
Building only for 4.15.0-24-generic
Building for architecture x86_64
Building initial module for 4.15.0-24-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/bcmwl-kernel-source.0.crash'
Error! Bad return status for module build on kernel: 4.15.0-24-generic (x86_64)
Consult /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log for more information.
modprobe: FATAL: Module wl not found in directory /lib/modules/4.15.0-24-generic
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.122ubuntu8.11) ...
update-initramfs: Generating /boot/initrd.img-4.15.0-24-generic
W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_14.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_ver8_7.bin for module i915
root@roman-Lenovo-G510:~# apt-get install bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
bcmwl-kernel-source is already the newest version (6.30.223.271+bdcom-0ubuntu1~1.2).
This command lspci -nn -d 14e4 outputs:
08:00.0 Network controller [0280]: Broadcom Limited BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Could you tell me how to fix my problem?
ProblemType: Package
DKMSBuildLog:
DKMS make.log for bcmwl-6.30.223.271+bdcom for kernel 4.15.0-24-generic (x86_64)
Вт июл 3 16:26:40 MSK 2018
make: Entering directory '/usr/src/linux-headers-4.15.0-24-generic'
Makefile:976: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
CFG80211 API is prefered for this kernel version
Using CFG80211 API
CC [M] /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.o
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c: In function ‘osl_os_get_image_block’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:1083:26: warning: passing argument 2 of ‘kernel_read’ makes pointer from integer without a cast [-Wint-conversion]
rdlen = kernel_read(fp, fp->f_pos, buf, len);
In file included from ./include/linux/huge_mm.h:7:0,
from ./include/linux/mm.h:463,
from /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/include/linuxver.h:65,
from /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:25:
./include/linux/fs.h:2858:16: note: expected ‘void *’ but argument is of type ‘loff_t {aka long long int}’
extern ssize_t kernel_read(struct file *, void *, size_t, loff_t *);
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:1083:37: warning: passing argument 3 of ‘kernel_read’ makes integer from pointer without a cast [-Wint-conversion]
./include/linux/fs.h:2858:16: note: expected ‘size_t {aka long unsigned int}’ but argument is of type ‘char *’
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:1083:42: warning: passing argument 4 of ‘kernel_read’ makes pointer from integer without a cast [-Wint-conversion]
./include/linux/fs.h:2858:16: note: expected ‘loff_t * {aka long long int *}’ but argument is of type ‘int’
CC [M] /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.o
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c: In function ‘wl_init_timer’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:2359:2: error: implicit declaration of function ‘init_timer’ [-Werror=implicit-function-declaration]
init_timer(&t->timer);
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:2360:10: error: ‘struct timer_list’ has no member named ‘data’
t->timer.data = (ulong) t;
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:2361:20: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
t->timer.function = wl_timer;
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target '/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.o' failed
make[1]: *** [/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.o] Error 1
Makefile:1552: recipe for target '_module_/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build' failed
make: *** [_module_/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build] Error 2
make: Leaving directory '/usr/src/linux-headers-4.15.0-24-generic'
DKMSKernelVersion: 4.15.0-24-generic
Date: Tue Jul 3 16:26:46 2018
DuplicateSignature: dkms:bcmwl-kernel-source:6.30.223.271+bdcom-0ubuntu1~1.2:/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:2359:2: error: implicit declaration of function ‘init_timer’ [-Werror=implicit-function-declaration]
Package: bcmwl-kernel-source 6.30.223.271+bdcom-0ubuntu1~1.2
PackageVersion: 6.30.223.271+bdcom-0ubuntu1~1.2
SourcePackage: bcmwl
Title: bcmwl-kernel-source 6.30.223.271+bdcom-0ubuntu1~1.2: bcmwl kernel module failed to build
Чт июл 5 16:26:16 MSK 2018
Using CFG80211 API
