I'm using following wifi hardware (08:00.0 Network controller [0280]: Broadcom Limited BCM43142 802.11b/g/n [14e4:4365] (rev 01))
network UNCLAIMED
       description: Network controller
       product: BCM43142 802.11b/g/n
       vendor: Broadcom Limited
       physical id: 0
       bus info: pci@0000:08:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:c1500000-c1507fff
This has just stopped working after recent update by Ubuntu which made me auto remove few files as they weren't needed.
I have tried following links none worked: Installing Broadcom Wireless Drivers https://grenangen.se/node/86
Kindly help
Sicerely
Like @Juxmix said, I disabled the proprietary driver, restarted and it didn't work. Then I executed the following command:
sudo apt-get install firmware-b43-installer
and it worked.
EDIT: The wifi with the b43 firmware was running a little bit slower then Broadcom one.
  1. disable the networking
  2. uinstall the b43 drivers
    sudo apt remove firmware-b43-installer
  3. follow the instructions on this link
Shonen
  • 31
I have the same Wireless card and have faced similar issue immediately after installing Ubuntu 16.04.
Please go to 'Additional Drivers' tab in 'Softwares & Updates'. Check if your wireless card is listed and ensure that it is using the proprietary drivers from Broadcom.
If the device is not listed or driver is not found, connect your system to Internet using a wired connection and install all updates using 'software updater'.
Run sudo apt-get update to refresh all the repositories.
For me, automatically found the proper drivers and the Wi-Fi started working after a restart. Hope this solves your issue.
Jrct
  • 96
I had the same problem with the same network controller, after updating. Tried winding back to an earlier version, network restart... Nothing worked.
What worked uninstalling "our" 16.04 version of the broadcom drivers:
sudo apt-get remove --purge bcmwl-kernel-source
Then installing the 18.04 binaries which can be found here:
https://packages.ubuntu.com/bionic/bcmwl-kernel-source
With this command or simply opening the file with the software center.
sudo dpkg -i bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu4_amd64.deb
The original source, from another part of Stackexchange can be found following this link:
https://elementaryos.stackexchange.com/questions/15842/bcm43142-and-linux-kernel-4-15-0-24-generic
I had the very same problem and I solved by selecting "Do not use this device" on the control panel. After appling and restarting it began to work fine. By the way the name of the wireles interface has changed to something like wlp2s0b1
Juxmix
