I am on Ubuntu 16.04 and I have this network card: https://www.tp-link.com/uk/products/details/cat-11_Archer-T6E.html
With kernel 4.14.x everything is working just fine. But when upgrading to 4.15.x or 4.16, I can not see any wifi connections. But I can get a temporary connection through my phone's usb.
lspci -knn | grep Net -A2 returns
04:00.0 Network controller [0280]: Broadcom Corporation BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03)
Subsystem: Broadcom Corporation BCM4360 802.11ac Wireless Network Adapter [14e4:0619]
Kernel modules: bcma
When I try to do modprobe wl
modprobe: FATAL: Module wl not found in directory /lib/modules/4.16.0-041600-generic
I have tried reinstalling bcmwl-kernel-source
sudo apt purge bcmwl-kernel-source
sudo apt-get install --reinstall linux-headers-generic
sudo apt-get install bcmwl-kernel-source
But this leads to
The following NEW packages will be installed:
bcmwl-kernel-source
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,544 kB of archives.
After this operation, 8,064 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 bcmwl-kernel-source amd64 6.30.223.271+bdcom-0ubuntu1~1.2 [1,544 kB]
Fetched 1,544 kB in 0s (2,774 kB/s)
Selecting previously unselected package bcmwl-kernel-source.
(Reading database ... 499695 files and directories currently installed.)
Preparing to unpack .../bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu1~1.2_amd64.deb ...
Unpacking bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) ...
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) ...
Loading new bcmwl-6.30.223.271+bdcom DKMS files...
First Installation: checking all kernels...
Building only for 4.16.0-041600-generic
Building for architecture x86_64
Building initial module for 4.16.0-041600-generic
ERROR (dkms apport): kernel package linux-headers-4.16.0-041600-generic is not supported
Error! Bad return status for module build on kernel: 4.16.0-041600-generic (x86_64)
Consult /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log for more information.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.122ubuntu8.11) ...
update-initramfs: Generating /boot/initrd.img-4.16.0-041600-generic
And here is the output of /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log
