I had installed Cryptkeeper in Ubuntu 16.04 lts.
I have upgraded Ubuntu 16.04 to 18.04.
After I upgraded to Ubuntu 18.04 , I completely lost my file which were encrypted through Cryptkeeper in Ubuntu 16.04. There are only folders where I kept my files.
Now when I try to install Cryptkeeper in Ubuntu 18.04 through terminal it says
E: Package 'cryptkeeper' has no installation candidate
Does anyone know how to bring back my files without degrading Ubuntu to 16.04 LTS?
Or, does anyone know of another file encryption program, as easy to install and use as Cryptkeeper, that will work reliably on Ubuntu 18.04 ?
pomsky
  • 70,557
lathhik
  • 41
You can use GNOME EncFS Manager as an alternative, it lets you import your old encrypted folders.
To install it from PPA , first run
sudo add-apt-repository ppa:gencfsm/ppa
sudo apt-get update
Then install GNOME EncFS Manager by running
sudo apt install gnome-encfs-manager
Statutory warning: EncFS is not a very secure way to encrypt files, you may consider alternative methods.
pomsky
  • 70,557
Cryptkeeper's just a front-end for EncFS, so you could at least install & use EncFS directly in a terminal to read your old encrypted files.
The package is called encfs so install that (you'll have to enable the universe repository if it's not enabled already) and basically just run
encfs ~/encrypted-folder ~/mount-point
Or you could attempt to install the older version of cryptkeeper, by downloading it's .deb file from Ubuntu's packages webpage for xenial here https://packages.ubuntu.com/xenial/cryptkeeper then attempting to install it with
dpkg -i file.deb
But it's not at all guaranteed to work correctly, or at all, or even install.
pomsky
  • 70,557
Xen2050
  • 8,943
