How can I enable touch pad gestures(multi touch effects) of alps touch pad which comes with dell inspiron n5110 in ubuntu 11.10. These gestures worked fine with windows.
Asked
Active
Viewed 1.2k times
This blog post contains instructions for installing patched mouse drivers, which enable correct recognition of your touchpad: http://nwoki.wordpress.com/2012/10/02/multitouch-fix-for-alps-touchpad/ Even this is a little outdated, as there have been several updates to the drivers since.
In short: Download psmouse-alps-1.3: http://www.dahetral.com/public-download/psmouse-alps-1.3.tbz/view Then (using sudo / root):
- Extract the folder
psmouse-alps-1.3to/usr/source - cd to
/usr/source dkms add psmouse-alps-1.3dkms autoinstallrmmod psmouse && modprobe psmouse
Bam! Working multitouch! :-)
Possible duplicate: Enable two-finger scrolling on ALPS touchpad
Md Enzam Hossain
- 161
If you want to enable your Dell Inspiron 15R Touchpad:
- download that
alps-dkmspackage and install it in/usr/src. - from a terminal, navigate to
/usr/src/psmouse-alps-0.10/srcand thengedit alps.c - in
alps.cscroll down and copy the/* Dell Vostro 1400 */line completely. In that line you will have to replace first 3 matches, that is , replace 0x73 , 0x02 , 0x50 with 0x73 , 0x03 , 0x50 . - Save the file and return to the terminal. In the terminal type
dkms add -m psmouse -v alps-0.10 - After this, type
dkms build -m psmouse -v alps-0.10 - after build is complete, install it with
dkms install -m psmouse -v alps-0.10 - after it installs it successfully, type
rmmod psmouse && modprobe psmouseThis will reload your psmouse module. - Next, type
xinput --listto see whether it loaded successfully or not. If it showsAlps/PS2 Alps GlidePointin the xinput , than congrats. And i bet it will show as i got it working by this! If you need complete patched module , you can ask me :)
