91
On Ubuntu 18.04, I have connected my laptop to an external display and I am able to set the external display as primary and external display only mode. But when I turn on my laptop or log out from my session the display login screen is displayed only on my(internal) laptop screen. But once I login the display switches to external only and my laptop screen turns off as expected.
Is there a way I can make the login screen appear only on the external screen on bootup or on logout as in 16.04? Also the login screen does not follow my cursor as in 16.04.
muru
  • 207,228
Aravind
  • 1,458
This is a known and reported bug with gdm3. The current workaround appears to be:
  1. Go into Settings > Devices > Displays and configure your monitors the way you want for your login screen (in your case, internal laptop display disabled). Click the "Save" button when done.
    (Note: Changing this setting with an alternate desktop environment—such as Cinnamon—may not propagate the intended change.)
  2. Copy your user's monitors.xml file into the home folder for gdm user.
To copy the monitors.xml file, open a terminal and perform the following:
sudo cp ~/.config/monitors.xml ~gdm/.config/monitors.xml
sudo chown gdm:gdm ~gdm/.config/monitors.xml
Then, reboot and see if your changes persist. If this doesn't work, try going through the whole process again. It took me two times in order to get it to stick. I was also able to reboot with my external display disconnected and it switched back to my internal laptop display. I rebooted again and reconnected it and it switches back to my external monitor.
Hope this helps!
Damian T.
  • 1,285
40
This Solved my Isuue:
And in the /etc/gdm3/custom.conf uncomment WaylandEnable=false
Aravind
  • 1,458
39
I too have an external monitor. This worked for me:
  • Set your display mode as desired using Settings > Devices > Displays
  • Open a terminal window by pressing CtrlAltT and then type:
    sudo cp ~/.config/monitors.xml /var/lib/gdm3/.config
  • Hit Enter
  • Reboot the computer
J D
  • 490
