Problem is as stated in the title. When I safe load using the motherboard graphics the screen works throughout login and after.
When I use my nvidea drivers (nvidea-418) the laptop screen works until I login, after I hit enter on my password it freezes around a tenth of a second later, and then my external monitor kicks in.
The whole xorg log file is too big to paste, but what I believe contains the relevant parts are:
[ 239.369] (--) Log file renamed from "/var/log/Xorg.pid-2609.log" to "/var/log/Xorg.0.log"
[ 239.370]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 239.370] Build Operating System: Linux 4.4.0-143-generic x86_64 Ubuntu
[ 239.370] Current Operating System: Linux ubuntu 5.0.0-13-generic #14-Ubuntu SMP Mon Apr 15 14:59:14 UTC 2019 x86_64
[ 239.370] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.0.0-13-generic root=UUID=1cecb776-9479-4233-9676-d8d303f4c25d ro quiet splash vt.handoff=1
[ 239.370] Build Date: 03 April 2019 09:03:57AM
[ 239.370] xorg-server 2:1.20.4-1ubuntu3 (For technical support please see http://www.ubuntu.com/support)
[ 239.370] Current version of pixman: 0.36.0
[ 239.370] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 239.370] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 239.371] (==) Log file: "/var/log/Xorg.0.log", Time: Mon May 6 11:34:50 2019
[ 239.371] (==) Using config file: "/etc/X11/xorg.conf"
[ 239.371] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 239.373] (==) ServerLayout "Layout0"
[ 239.373] (**) |-->Screen "Screen0" (0)
[ 239.373] (**) | |-->Monitor "Monitor0"
[ 239.374] (**) | |-->Device "Device0"
[ 239.374] (**) |-->Input Device "Keyboard0"
[ 239.374] (**) |-->Input Device "Mouse0"
[ 239.374] (==) Automatically adding devices
[ 239.374] (==) Automatically enabling devices
[ 239.374] (==) Automatically adding GPU devices
[ 239.374] (==) Automatically binding GPU devices
[ 239.374] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 239.374] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 239.374] Entry deleted from font path.
[ 239.374] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 239.374] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 239.374] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 239.374] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 239.374] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 239.374] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 239.375] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 239.375] (WW) Disabling Keyboard0
[ 239.375] (WW) Disabling Mouse0
[ 239.375] (II) Loader magic: 0x5575291c1020
[ 239.375] (II) Module ABI versions:
[ 239.375] X.Org ANSI C Emulation: 0.4
[ 239.375] X.Org Video Driver: 24.0
[ 239.375] X.Org XInput driver : 24.1
[ 239.375] X.Org Server Extension : 10.0
[ 239.376] (++) using VT number 2
[ 239.379] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
[ 239.380] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 239.382] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 239.382] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 239.384] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 239.387] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia-418/xorg,/usr/lib/xorg/modules"
[ 239.387] (**) OutputClass "Nvidia Prime" ModulePath extended to "/x86_64-linux-gnu/nvidia/xorg,/usr/lib/x86_64-linux-gnu/nvidia-418/xorg,/usr/lib/xorg/modules"
[ 239.387] (**) OutputClass "Nvidia Prime" setting /dev/dri/card1 as PrimaryGPU
[ 239.390] (--) PCI: (0@0:2:0) 8086:591b:1558:9501 rev 4, Mem @ 0xdd000000/16777216, 0xa0000000/536870912, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 239.390] (--) PCI:*(1@0:0:0) 10de:1ba1:1558:9501 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 239.390] (II) LoadModule: "glx"
[ 239.392] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 239.394] (II) Module glx: vendor="X.Org Foundation"
[ 239.394] compiled for 1.20.4, module version = 1.0.0
[ 239.394] ABI class: X.Org Server Extension, version 10.0
[ 239.394] (II) LoadModule: "nvidia"
[ 239.394] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia-418/xorg/nvidia_drv.so
[ 239.398] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 239.398] compiled for 4.0.2, module version = 1.0.0
[ 239.399] Module class: X.Org Video Driver
[ 239.399] (II) NVIDIA dlloader X Driver 418.56 Fri Mar 15 12:37:35 CDT 2019
[ 239.399] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 239.400] (II) systemd-logind: releasing fd for 226:1
[ 239.401] (II) Loading sub module "fb"
[ 239.401] (II) LoadModule: "fb"
[ 239.402] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 239.403] (II) Module fb: vendor="X.Org Foundation"
[ 239.403] compiled for 1.20.4, module version = 1.0.0
[ 239.403] ABI class: X.Org ANSI C Emulation, version 0.4
[ 239.403] (II) Loading sub module "wfb"
[ 239.403] (II) LoadModule: "wfb"
[ 239.403] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 239.404] (II) Module wfb: vendor="X.Org Foundation"
[ 239.404] compiled for 1.20.4, module version = 1.0.0
[ 239.404] ABI class: X.Org ANSI C Emulation, version 0.4
[ 239.404] (II) Loading sub module "ramdac"
[ 239.404] (II) LoadModule: "ramdac"
[ 239.404] (II) Module "ramdac" already built-in
[ 239.405] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 239.405] (==) NVIDIA(0): RGB weight 888
[ 239.405] (==) NVIDIA(0): Default visual is TrueColor
[ 239.405] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 239.406] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 239.406] (II) Applying OutputClass "Nvidia Prime" options to /dev/dri/card1
[ 239.406] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 239.406] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 239.406] (**) NVIDIA(0): Enabling 2D acceleration
[ 239.406] (II) Loading sub module "glxserver_nvidia"
[ 239.406] (II) LoadModule: "glxserver_nvidia"
[ 239.407] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia-418/xorg/libglxserver_nvidia.so
[ 239.434] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 239.434] compiled for 4.0.2, module version = 1.0.0
[ 239.434] Module class: X.Org Server Extension
[ 239.434] (II) NVIDIA GLX Module 418.56 Fri Mar 15 12:36:35 CDT 2019
[ 239.462] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 239.462] (--) NVIDIA(0): DFP-0 (boot)
[ 239.462] (--) NVIDIA(0): DFP-1
[ 239.462] (--) NVIDIA(0): DFP-2
[ 239.462] (--) NVIDIA(0): DFP-3
[ 239.462] (--) NVIDIA(0): DFP-4
[ 239.464] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1070 with Max-Q Design (GP104-A) at
[ 239.464] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 239.464] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 239.464] (--) NVIDIA(0): VideoBIOS: 86.04.6e.00.12
[ 239.464] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 239.494] (--) NVIDIA(GPU-0): Samsung C34J79x (DFP-0): connected
[ 239.494] (--) NVIDIA(GPU-0): Samsung C34J79x (DFP-0): Internal TMDS
[ 239.494] (--) NVIDIA(GPU-0): Samsung C34J79x (DFP-0): 600.0 MHz maximum pixel clock
[ 239.494] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 239.494] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 239.494] (--) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 239.494] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 239.494] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 239.494] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 239.494] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 239.494] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 239.494] (--) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[ 239.494] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 239.494] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 239.494] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 239.499] (==) NVIDIA(0):
[ 239.499] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 239.499] (==) NVIDIA(0): will be used as the requested mode.
[ 239.500] (II) NVIDIA(0): Validated MetaModes:
[ 239.500] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 239.500] (II) NVIDIA(0): Virtual screen size determined to be 3440 x 1440
[ 239.511] (--) NVIDIA(0): DPI set to (109, 110); computed from "UseEdidDpi" X config
[ 239.512] (--) NVIDIA(0): option
[ 239.512] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 239.512] (II) NVIDIA: access.
[ 239.537] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 239.571] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 239.571] (==) NVIDIA(0): Backing store enabled
[ 239.571] (==) NVIDIA(0): Silken mouse enabled
[ 239.571] (**) NVIDIA(0): DPMS enabled
[ 239.572] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 239.572] (II) Loading sub module "dri2"
[ 239.572] (II) LoadModule: "dri2"
[ 239.572] (II) Module "dri2" already built-in
[ 239.572] (II) NVIDIA(0): [DRI2] Setup complete
[ 239.572] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 239.572] (II) Initializing extension Generic Event Extension
[ 239.572] (II) Initializing extension SHAPE
[ 239.572] (II) Initializing extension MIT-SHM
[ 239.572] (II) Initializing extension XInputExtension
[ 239.573] (II) Initializing extension XTEST
[ 239.573] (II) Initializing extension BIG-REQUESTS
[ 239.573] (II) Initializing extension SYNC
[ 239.573] (II) Initializing extension XKEYBOARD
[ 239.573] (II) Initializing extension XC-MISC
[ 239.573] (II) Initializing extension SECURITY
[ 239.573] (II) Initializing extension XFIXES
[ 239.573] (II) Initializing extension RENDER
[ 239.573] (II) Initializing extension RANDR
[ 239.574] (II) Initializing extension COMPOSITE
[ 239.574] (II) Initializing extension DAMAGE
[ 239.574] (II) Initializing extension MIT-SCREEN-SAVER
[ 239.574] (II) Initializing extension DOUBLE-BUFFER
[ 239.574] (II) Initializing extension RECORD
[ 239.574] (II) Initializing extension DPMS
[ 239.574] (II) Initializing extension Present
[ 239.574] (II) Initializing extension DRI3
[ 239.574] (II) Initializing extension X-Resource
[ 239.574] (II) Initializing extension XVideo
[ 239.574] (II) Initializing extension XVideo-MotionCompensation
[ 239.574] (II) Initializing extension SELinux
[ 239.574] (II) SELinux: Disabled on system
[ 239.574] (II) Initializing extension GLX
[ 239.575] (II) Initializing extension GLX
[ 239.575] (II) Indirect GLX disabled.
[ 239.575] (II) GLX: Another vendor is already registered for screen 0
[ 239.575] (II) Initializing extension XFree86-VidModeExtension
[ 239.575] (II) Initializing extension XFree86-DGA
[ 239.575] (II) Initializing extension XFree86-DRI
[ 239.575] (II) Initializing extension DRI2
[ 239.575] (II) Initializing extension NV-GLX
[ 239.575] (II) Initializing extension NV-CONTROL
[ 239.575] (II) Initializing extension XINERAMA
[ 239.625] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 239.625] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 239.625] (II) LoadModule: "libinput"
[ 239.625] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 239.626] (II) Module libinput: vendor="X.Org Foundation"
[ 239.626] compiled for 1.20.4, module version = 0.28.2
[ 239.626] Module class: X.Org XInput Driver
[ 239.626] ABI class: X.Org XInput driver, version 24.1
[ 239.626] (II) Using input driver 'libinput' for 'Power Button'
[ 239.627] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 40 paused 0
[ 239.627] (**) Power Button: always reports core events
[ 239.627] (**) Option "Device" "/dev/input/event3"
[ 239.627] (**) Option "_source" "server/udev"
[ 239.628] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 239.628] (II) event3 - Power Button: device is a keyboard
[ 239.628] (II) event3 - Power Button: device removed
[ 239.628] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 239.628] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 239.628] (**) Option "xkb_model" "pc105"
[ 239.628] (**) Option "xkb_layout" "gb"
[ 239.638] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 239.638] (II) event3 - Power Button: device is a keyboard
[ 239.638] (II) config/udev: Adding input device Video Bus (/dev/input/event23)
[ 239.638] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 239.638] (II) Using input driver 'libinput' for 'Video Bus'
[ 239.639] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 43 paused 0
[ 239.639] (**) Video Bus: always reports core events
[ 239.639] (**) Option "Device" "/dev/input/event23"
[ 239.639] (**) Option "_source" "server/udev"
[ 239.640] (II) event23 - Video Bus: is tagged by udev as: Keyboard
[ 239.640] (II) event23 - Video Bus: device is a keyboard
[ 239.640] (II) event23 - Video Bus: device removed
[ 239.640] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input31/event23"
[ 239.640] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 239.640] (**) Option "xkb_model" "pc105"
[ 239.640] (**) Option "xkb_layout" "gb"
[ 239.641] (II) config/udev: Adding input device Video Bus (/dev/input/event24)
[ 239.641] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 239.641] (II) Using input driver 'libinput' for 'Video Bus'
[ 239.641] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 44 paused 0
[ 239.641] (**) Video Bus: always reports core events
[ 239.641] (**) Option "Device" "/dev/input/event24"
[ 239.641] (**) Option "_source" "server/udev"
[ 239.642] (II) event24 - Video Bus: is tagged by udev as: Keyboard
[ 239.642] (II) event24 - Video Bus: device is a keyboard
[ 239.642] (II) event24 - Video Bus: device removed
[ 239.642] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:12/LNXVIDEO:01/input/input32/event24"
[ 239.642] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 239.642] (**) Option "xkb_model" "pc105"
[ 239.642] (**) Option "xkb_layout" "gb"
[ 239.643] (II) event24 - Video Bus: is tagged by udev as: Keyboard
[ 239.643] (II) event24 - Video Bus: device is a keyboard
[ 239.643] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 239.643] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 239.643] (II) Using input driver 'libinput' for 'Power Button'
[ 239.643] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[ 239.643] (**) Power Button: always reports core events
[ 239.643] (**) Option "Device" "/dev/input/event0"
[ 239.643] (**) Option "_source" "server/udev"
[ 239.644] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 239.644] (II) event0 - Power Button: device is a keyboard
[ 239.644] (II) event0 - Power Button: device removed
[ 239.644] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 239.644] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 239.644] (**) Option "xkb_model" "pc105"
[ 239.644] (**) Option "xkb_layout" "gb"
[ 239.645] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 239.645] (II) event0 - Power Button: device is a keyboard
[ 239.645] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 239.645] (II) No input driver specified, ignoring this device.
[ 239.645] (II) This device may have been added with another device file.
[ 239.645] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 239.645] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 239.645] (II) Using input driver 'libinput' for 'Sleep Button'
[ 239.646] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 46 paused 0
[ 239.646] (**) Sleep Button: always reports core events
[ 239.646] (**) Option "Device" "/dev/input/event1"
[ 239.646] (**) Option "_source" "server/udev"
[ 239.646] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 239.646] (II) event1 - Sleep Button: device is a keyboard
[ 239.646] (II) event1 - Sleep Button: device removed
[ 239.646] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 239.646] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 239.646] (**) Option "xkb_model" "pc105"
[ 239.646] (**) Option "xkb_layout" "gb"
[ 239.647] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 239.647] (II) event1 - Sleep Button: device is a keyboard
[ 239.647] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event256)
[ 239.647] (II) No input driver specified, ignoring this device.
[ 239.647] (II) This device may have been added with another device file.
[ 239.647] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event257)
[ 239.648] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event258)
[ 239.648] (II) No input driver specified, ignoring this device.
[ 239.648] (II) This device may have been added with another device file.
[ 239.648] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event6)
[ 239.648] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 239.648] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 239.649] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 47 paused 0
[ 239.649] (**) Logitech USB Receiver: always reports core events
[ 239.649] (**) Option "Device" "/dev/input/event6"
[ 239.649] (**) Option "_source" "server/udev"
[ 239.649] (II) event6 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 239.649] (II) event6 - Logitech USB Receiver: device is a keyboard
[ 239.649] (II) event6 - Logitech USB Receiver: device removed
[ 239.649] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C53D.0001/input/input13/event6"
[ 239.650] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[ 239.650] (**) Option "xkb_model" "pc105"
[ 239.650] (**) Option "xkb_layout" "gb"
[ 239.650] (II) event6 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 239.650] (II) event6 - Logitech USB Receiver: device is a keyboard
[ 239.651] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event7)
[ 239.651] (**) Logitech USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 239.651] (II) Using input driver 'libinput' for 'Logitech USB Receiver Mouse'
[ 239.665] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 48 paused 0
[ 239.665] (**) Logitech USB Receiver Mouse: always reports core events
[ 239.665] (**) Option "Device" "/dev/input/event7"
[ 239.665] (**) Option "_source" "server/udev"
I'm assuming one of the internal display ports should be reading as connected? Any help as to how to fix or further diagnose is much appreciated
