11
I need a way to change the boot-up and login screen resolution to 1920 x 1080 resolution. I have a 4K display on my laptop and can't read the text in the grub bootloader screen properly as they aren't scaled. Even the login screen have some qirkiness like it missed scaling the mouse cursor.
I figure I could solve this if I can just lower the boot-up resolution and login screen, but I don't know what's the best way to about doing this. In the past, I have changed the boot-up screen resolution via kernel boot command parameters and muck about with gnome gdm. But if I don't do things properly, the changes may be overwritten during regular Ubuntu update.
Please provide advice if you have experience in doing this. Thanks.
Bernard Wei
  • 2,175
  • 14
  • 23
6 Answers6
10
Just want to add that I found a way to change the login screen resolution. That part of my problem has been asked and answered, see how to change gdm3 thread.
After setting up the monitor resolution and zoom level I wanted, I simply copy the settings to gdm3 .config directory, make any further changes you need and then reboot the PC.
sudo cp -i .config/monitors.xml /var/lib/gdm3/.config/
sudo vi /var/lib/gdm3/.config/monitors.xml
You probably also need to do the following before rebooting. Select gdm3 when prompted.
sudo dpkg-reconfigure gdm3
Bernard Wei
  • 2,175
  • 14
  • 23
For 18.04 there are a couple of things you can try.
The first thing to do is to make sure the resolution of 1920 x 1080 is supported in grub. To do that reboot your computer and hit Esc repeatedly until you get the purple screen with the recovery and grub options. Hit c to get a grub prompt. At the grub prompt, type:
videoinfo
and hit Enter.
Look at the list of supported resolutions, and make sure 1920 x 1080 is there. If so, type:
exit
to exit grub and boot.
The boot screen resolution is changed by changing your default grub settings. Open a terminal and enter:
sudo nano /etc/default/grub
Use the down arrow or Page Down until you see the line that looks like this:
#GRUB_GFXMODE=640x480
Below that line, enter the following, substituting the 1920x1080 for a supported resolution:
GRUB_GFXMODE=1920x1080
GRUB_GFXPAYLOAD_LINUX=keep
To save your changes, hit Ctrl+O (with O as in Ohio, not zero). To exit nano, hit Ctrl+X. Now, update grub:
sudo update-grub
That should solve the problem in grub, and won't be overwritten by an update. For the login screen, you may be able to fix it with the 4K settings in Ubuntu 18.04. Go Settings -> Devices -> Displays and set Scale to 200%. I'm not sure if that will affect the desktop manager or not, but it's the first thing I'd try.
linux4me
  • 416
For a fresh install of Ubuntu 22.04, bernard-wei's answer is the right one.
sudo cp ~/.config/monitors.xml /var/lib/gdm3/.config/monitors.xml
I have had several issues making me think it was wrong:
  • There was no ~/.config/monitors.xml. (by default the gnome display settings can automatically adapt to your monitor)
    Make any change in Settings > Display so that this file is created
  • Create the /var/lib/gdm3/.config folder
From when you have done those 2 steps, you can also install and use this tool to customize your login screen (background, ...)
https://realmazharhussain.github.io/gdm-settings/
The button in Display > Apply current display settings will basically do the above copy, but only if you have done the above steps
Display in Login Manager Settings
I would recommend using the excellent third party tool Grub Customizer, which can be installed with:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt update
sudo apt install grub-customizer
# To remove
# sudo apt remove --autoremove grub-customizer
Specifically, to control the resolution:
  • Open the program (type "grub customizer" in your dash), it will prompt you for your password;
  • Click the tab "Appearance settings";
  • Select the option "custom resolution";
  • Select the resolution of choice in the dropdown menu (the format is width-by-height-by-ncolors, e.g. 1600x1200x24).
NOTE: The resolutions that GRUB can use vary on each machine, and Grub Customizer does not seem to be aware of this. To know which resolutions are supported on your machine, reboot and type c when at the GRUB menu (i.e. instead of selecting a kernel option), and then type videoinfo in the prompt. Write down the resolutions supported (or take a picture with your phone if needed), and then type reboot.
I use the guide by Alberto. Run:
sudo cp ~/.config/monitors.xml ~gdm/.config/monitors.xml
where ~gdm is /var/lib/gdm3. Then run:
sudo chown gdm:gdm ~gdm/.config/monitors.xml
Eideen
I had the same problem with a lot of distribution, I just had to say I tried the display options, I tried the grub, and I tried the graphic card option and nothing helped. The only thing that helped me is changing the resolution of the lightdm log-in manager.
Here is the website with the full explanation of how to do it: https://sudo-juice.com/lightdm-resolution/
And one thing "xrandr --output HDMI-1-1 --primary --mode 1920x1080" = two lines not one
"display-setup-script=/usr/share/lightdmxrandr.sh" = and this is with one cause the original one is not working for me.
