I believe Nautilus is the file system in Ubuntu. When I have two tabs open, in say my home directory, how do I move between them easily?
Is there a shortcut key?
For example: In Firefox, Ctrl + Tab allows you move directly between tabs and that would be very useful in my own file system.
Alt+Num will move you to the tab that Num corresponds to. So:
  • Alt+1 for the first tab.
  • Alt+2 for the second tab.
  • Alt+3 for the third tab.
and so on.
Good luck!
  • Alt + Num for direct access; and
  • Ctrl+PgUp and Ctrl+PgDn to navigate sequentially through tabs.
Daniel C
  • 4,170
In order to avoid duplicating comments, see this answer for a working Ctrl+Tab:
How can I change the keybindings in Nautilus?
