Ok, with some info from other answers, you can try this untested method:
From Catch lid close and open events
The script you want to call when the lid opens or closes has to be stored
in /etc/acpi/lid.sh.
Then there has to be created the correct file /etc/acpi/events/lm_lid with the content as follows:
event=button/lid.*
action=/etc/acpi/lid.sh
Reboot your system to let this take effect. Or maybe it is enough to restart your ACPI using
sudo /etc/init.d/acpid restart
From https://unix.stackexchange.com/questions/252002/help-testing-special-file-in-sys-class-net and How can I suspend/hibernate from command line?
the /etc/acpi/lid.sh script will look like this (change yournetworkcardname for your name of your network card. Use ifconfig to find it). You can choose between suspend or hibernate.
#!/bin/bash
if [ "$(head -c1 /sys/class/net/yournetworkcardname/carrier)" -eq 0 ]; then
systemctl suspend
fi
Test the script with bash -x /etc/acpi/lid.sh and make sure it works. You might have to add the following to run the script as sudo without being prompted with a password, from https://unix.stackexchange.com/questions/18830/how-to-run-a-specific-program-as-root-without-a-password-prompt:
myusername ALL = (root) NOPASSWD: /etc/acpi/lid.sh
Maybe you will also have to call the script in the action with sudo.
