How can I hide top bar in Gnome 3.28 Ubuntu 18.04?
How can the hide-top-bar extension be installed?
First open the terminal and install chrome-gnome-shell package:
sudo apt install chrome-gnome-shell
Then install one of these extensions:
Finally, head over to the GNOME Extensions page for the "Hide Top Bar" extension and enable the ON/OFF switch for the extension to install.
For reference, install gnome-tweaks and run:
sudo apt install gnome-shell-extension-autohidetopbar
Then log out and back in. The option to auto hide the top bar will be available from gnome-tweaks tool in the extensions section.
The simplest and working way I found is to install the Dash-to-Panel GNOME extension. Works like a charm.
You can toggle it from the browser itself.
I was having the same problem about removing top bar. What I do is hack into the theme css, and edit it in place.
Edit /usr/share/gnome-shell/theme/ubuntu.css, add to the bottom
#panel, #panel * {
height: 0px;
color: rgba(0,0,0,0);
The top bar is there, but won't be visible and can't interact with user.
gnome-extensions command line
The snapification of browsers broke the chrome-gnome-shell method mentioned at https://askubuntu.com/a/1029905/52975 with error message:
Although GNOME Shell integration extension is running, native host connector is not detected
as mentioned at Although GNOME Shell integration extension is running, native host connector is not detected so if you don't want to find a non snapified browser, you can download the Zip manually from: https://extensions.gnome.org/extension/3906/remove-app-menu/ or:
wget https://extensions.gnome.org/extension-data/hidetopbarmathieu.bidon.ca.v97.shell-extension.zip
You can check your GNOME shell version as shown at: How do I check my version of GNOME-Shell? with either:
gnome-extensions version
gnome-shell --version
to determine which versions are compatible based on the extensions website. Then:
gnome-extensions install hidetopbarmathieu.bidon.ca.v97.shell-extension.zip
gnome-extensions enable hidetopbar@mathieu.bidon.ca
As soon as you run enable, the top bar is immediately gone.
I wish we had a more decent standard single command CLI method, see: https://unix.stackexchange.com/questions/617288/command-line-tool-to-install-gnome-shell-extensions
Other extensions of interest:
hidetopbar@mathieu.bidon.ca, I managed to remove both the top bar and the title bar on Ubuntu 21.10, effectively making all maximized windows become full screen! You can make them not-fullscreen with the default shortcut Alt + F10 if needed (since there's not title bar to click the unmaximize button on).Related:
Tested on Ubuntu 21.10.
