47
I can't fetch content from the web using `curl. I tried to install it and got the output below:
The following packages have unmet dependencies. curl : Depends: libcurl4 (= 7.58.0-2ubuntu3) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I've checked for held packages both with sudo apt-mark showheld and dpkg -l | grep ^h, but I get no results either way.
Also, when I attempt to install libcurl4, it almost breaks my system, since it attempts to remove these packages:
libcurl3 mongodb-enterprise mongodb-enterprise-server mongodb-enterprise-tools msodbcsql msodbcsql17 mssql-tools php7.1-curl r-base r-base-core
  r-base-dev r-base-html r-cran-boot r-cran-class r-cran-codetools r-cran-foreign r-cran-getopt r-cran-kernsmooth r-cran-lattice r-cran-littler
  r-cran-mass r-cran-matrix r-cran-mgcv r-cran-nlme r-cran-nnet r-cran-rpart r-cran-spatial r-cran-survival r-recommended slack-desktop
  virtualbox-5.2
Edit
This is the output of cat /etc/apt/sources.list:
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution. deb http://gb.archive.ubuntu.com/ubuntu/ bionic main restricted deb-src
Major bug fix updates produced after the final release of the
distribution. deb http://gb.archive.ubuntu.com/ubuntu/ bionic-updates main restricted deb-src
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team. deb http://gb.archive.ubuntu.com/ubuntu/ bionic universe deb-src
deb http://gb.archive.ubuntu.com/ubuntu/ bionic-updates universe deb-src http://gb.archive.ubuntu.com/ubuntu/ bionic-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team. deb http://gb.archive.ubuntu.com/ubuntu/ bionic multiverse deb-src http://gb.archive.ubuntu.com/ubuntu/ bionic
multiverse
deb http://gb.archive.ubuntu.com/ubuntu/ bionic-updates multiverse deb-src http://gb.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb-src http://gb.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users. deb http://archive.canonical.com/ubuntu bionic partner deb-src
deb http://security.ubuntu.com/ubuntu bionic-security main restricted deb-src http://security.ubuntu.com/ubuntu bionic-security main restricted
deb http://security.ubuntu.com/ubuntu bionic-security universe deb-src http://security.ubuntu.com/ubuntu bionic-security universe
deb http://security.ubuntu.com/ubuntu bionic-security multiverse deb-src http://security.ubuntu.com/ubuntu bionic-security multiverse
deb http://gb.archive.ubuntu.com/ubuntu/ bionic-proposed main multiverse universe restricted #Not for humans during development stage of release bionic
ded-src http://archive.ubuntu.com/ubuntu/ trusty-backports main restricted ui=niverse
deb http://gb.archive.ubuntu.com/ubuntu/ bionic-backports main restricted multiverse universe
Joseph-L-S
  • 1,113
5 Answers5
48
This problem is common in multiple packages in ubuntu recent LTS. Preinstalled packages have a possible error in version convention because "18.04" and other strings referencing repo are considering as part of the package version and not reference to the repo.
The workaround is uninstall preinstalled dependency and then reinstall. After that, you can install cURL.
apt remove -y libcurl4
apt install -y libcurl4 curl
Other packages with that problem are okular and libsdl2, and the solution is the same, track problematic dependencies, remove and reinstall.
Also, you can use apt downgrade mechanism (thus, is not necessary to uninstall packages that depend of libcurl4).
apt install -y libcurl4=7.58.0-2ubuntu3
apt install -y curl
Install curl from source. That worked for me.
git clone https://github.com/curl/curl.git
cd curl
./buildconf
./configure
make
make test # optional
sudo make install
Eliah Kagan
  • 119,640
Try to use
sudo apt install libcurl4-openssl-dev
If you get any errors, try the commands below and then the above command again.
sudo apt update
sudo apt remove libcurl4
Melebius
  • 11,750
Hearen
  • 253
To start a clean slate first clean you packages:
sudo apt autoremove
Then you install libcurl4 and curl
aburbanol
  • 141
Install libcurl4 by using sudo apt-get install libcurl4 then, Install curl by using sudo apt-get install curl
If you get "CURL_OPENSSL_4 not found error" then, remove "/usr/lib/x86_64-linux-gnu/libcurl.so.4" file by using following command: sudo rm /usr/lib/x86_64-linux-gnu/libcurl.so.4
Create softlink again by using following command : sudo ln -s /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /usr/lib/x86_64-linux-gnu/libcurl.so.4
