On Lubuntu 18.04, I have installed mongodb, by following https://docs.mongodb.com/manual/tutorial/install-mongodb-on-ubuntu/#install-mongodb-community-edition
sudo apt install -y mongodb-org mongodb-org-server libcurl3
and now want to install curl
$ sudo apt install curl
Reading package lists... Done
Building dependency tree
curl : Depends: libcurl4 (= 7.58.0-2ubuntu3.2) but it is not going to be installed
I followed https://askubuntu.com/a/1051988/1471
you can use apt downgrade mechanism (thus, is not necessary to uninstall packages that depend of libcurl4).
apt install -y libcurl4=7.58.0-2ubuntu3 apt install -y curl
But then libcurl3 and mongodb were removed
$ sudo apt install -y libcurl4=7.58.0-2ubuntu3
The following packages were automatically installed and are no longer required:
calibre-bin fonts-mathjax geoclue-2.0 iio-sensor-proxy libbrotli1 libchm1 libgeoclue-2-0 libjs-coffeescript libjs-mathjax libpodofo0.9.5 libqt5designer5 libqt5help5
libqt5positioning5 libqt5sensors5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5webchannel5 libqt5webkit5 libqt5xml5 libwoff1 mongodb-org-mongos mongodb-org-shell
mongodb-org-tools python-apsw python-asn1crypto python-bs4 python-cffi-backend python-chardet python-cherrypy3 python-cryptography python-cssselect python-cssutils
python-dateutil python-dbus python-dnspython python-enum34 python-feedparser python-html5-parser python-html5lib python-idna python-ipaddress python-libxml2 python-lxml
python-markdown python-mechanize python-msgpack python-netifaces python-olefile python-openssl python-pil python-pygments python-pyparsing python-pyqt5 python-pyqt5.qtsvg
python-pyqt5.qtwebkit python-regex python-repoze.lru python-routes python-simplejson python-sip python-six python-utidylib python-webencodings python-webob python-yaml
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
libcurl3 mongodb-org mongodb-org-server
The following NEW packages will be installed:
libcurl4
0 upgraded, 1 newly installed, 3 to remove and 0 not upgraded.
Need to get 214 kB of archives.
After this operation, 61.6 MB disk space will be freed.
Get:1 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 libcurl4 amd64 7.58.0-2ubuntu3 [214 kB]
Fetched 214 kB in 1s (419 kB/s)
(Reading database ... 235089 files and directories currently installed.)
Removing mongodb-org (4.0.0) ...
Removing mongodb-org-server (4.0.0) ...
Removing libcurl3:amd64 (7.58.0-2ubuntu2) ...
Selecting previously unselected package libcurl4:amd64.
(Reading database ... 235068 files and directories currently installed.)
Preparing to unpack .../libcurl4_7.58.0-2ubuntu3_amd64.deb ...
Unpacking libcurl4:amd64 (7.58.0-2ubuntu3) ...
Setting up libcurl4:amd64 (7.58.0-2ubuntu3) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for man-db (2.8.3-2) ...
When I tried to install mongodb, then libcurl4 will be removed
$ sudo apt install -y mongodb-org mongodb-org-server
libqt5positioning5 libqt5sensors5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5webchannel5 libqt5webkit5 libqt5xml5 libwoff1 python-apsw python-asn1crypto python-bs4
python-cffi-backend python-chardet python-cherrypy3 python-cryptography python-cssselect python-cssutils python-dateutil python-dbus python-dnspython python-enum34
python-feedparser python-html5-parser python-html5lib python-idna python-ipaddress python-libxml2 python-lxml python-markdown python-mechanize python-msgpack python-netifaces
python-olefile python-openssl python-pil python-pygments python-pyparsing python-pyqt5 python-pyqt5.qtsvg python-pyqt5.qtwebkit python-regex python-repoze.lru python-routes
The following additional packages will be installed:
libcurl3
libcurl4
0 upgraded, 3 newly installed, 1 to remove and 0 not upgraded.
Need to get 15.7 MB of archives.
After this operation, 61.6 MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 libcurl3 amd64 7.58.0-2ubuntu2 [214 kB]
Get:2 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/4.0/multiverse amd64 mongodb-org-server amd64 4.0.0 [15.5 MB]
Get:3 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/4.0/multiverse amd64 mongodb-org amd64 4.0.0 [3,518 B]
Fetched 15.7 MB in 25s (639 kB/s)
(Reading database ... 235073 files and directories currently installed.)
Removing libcurl4:amd64 (7.58.0-2ubuntu3) ...
Selecting previously unselected package libcurl3:amd64.
Preparing to unpack .../libcurl3_7.58.0-2ubuntu2_amd64.deb ...
Unpacking libcurl3:amd64 (7.58.0-2ubuntu2) ...
Selecting previously unselected package mongodb-org-server.
Preparing to unpack .../mongodb-org-server_4.0.0_amd64.deb ...
Unpacking mongodb-org-server (4.0.0) ...
Selecting previously unselected package mongodb-org.
Preparing to unpack .../mongodb-org_4.0.0_amd64.deb ...
Unpacking mongodb-org (4.0.0) ...
Setting up libcurl3:amd64 (7.58.0-2ubuntu2) ...
Setting up mongodb-org-server (4.0.0) ...
Setting up mongodb-org (4.0.0) ...
How shall I install both curl and mongodb
