i am trying to use curl and
curl -H "Content-Type: application/json" -X POST -d '{"items":[{"name":"first order","id":42}]}' http://localhost:8080/create-order
responds with
curl: /home/sara/LD_LIBRARY/libcurl.so.4: version `CURL_OPENSSL_4' not found (required by curl)
followed the solution given (here)[curl is not working on Ubuntu 18.04 LTS but no luck
sarah w
  • 243
Run this command : locate libcurl.so.4 Result will be :
  1. /YOUR_PATH/libcurl.so.4 (generally the path is "/usr/lib/x86_64-linux-gnu/libcurl.so.4")
  2. /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0
Remove the file which is causing the error using sudo rm /YOUR_PATH/libcurl.so.4 command.
Recreate softlink by using following command : sudo ln -s /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /YOUR_PATH/libcurl.so.4
