I installed Ubuntu 20.04 Server on my 2014 Macbook Pro and it all works great with the USB to ethernet adapter. However, when I try to use the Thunderbolt 2 to ethernet adapter I can't get the network connection to work. Running ip a shows (what I think is) the Thunderbolt interface (ens9) as DOWN, so I ran sudo ip link ens9 up. Then the Macbook shows up as a device in my router, but I still can't access it (have a web server running on it that works fine with the USB adapter). Running ping google.com gives: ping: google.com: Temporary failure in name resolution.
I haven't installed any drivers, just simply plugged in the Thunderbolt adapter and booted up. Would be very happy for some help to troubleshoot. Thanks in advance!
EDIT:
Running cat /etc/netplan/*.yaml gives:
# This is the network config written in 'subiquity'
network:
ethernets:
enx00f76f6f62ca:
dhcp4: true
version: 2
And running sudo lshw -C network gives:
*-network
description: Network controller
product: BCM4360 802.11ac Wireless Network Adapter
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:03:00.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=bcma-pci-bridge latency=0
resources: irq:18 memory:b0600000-b0607fff memory:b0400000-b05fffff
*-network DISABLED
description: Ethernet interface
product: NetXtreme BCM57762 Gigabit Ethernet PCIe
physical id: 0
bus info: pci@0000:0a:00.0
logical name: ens9
version: 00
serial: 18:7e:b9:0a:c7:d6
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=57762-a1.10 latency=0 link=no multicast=yes port=twisted pair
resources: irq:19 memory:bcc00000-bcc0ffff memory:bcc10000-bcc1ffff memory:b0c00000-b0c0ffff
