My host is ubuntu 11.04. The guest is WinXP VirtualBox is 4.0.10
The serial port works well with putty in ubuntu.
I setup as: COM1/4/0x3F8/Host Device/ Port Path: /dev/ttyS0
Then I close putty, to make serial port is free. After windows XP and Device Manager started, I see there is a LPT1 instead of COM1 under "Ports(COM & LPT)"
I followed the procedure in this topic( How to access serial ubuntu host serial port on VirtualBox guest OS ), but the issue keeps not resolved.
Thanks for any help.
You may suffer from a bug in earlier versions of virtual box:
https://www.virtualbox.org/ticket/7411
This issue was fixed from Virtual Box release 4.1.0.
You may succed by simply upgrading to the most recent version (at present 4.1.8).
Takkat
  • 144,580
