NUC model: NUC7i3BNK OS: Lubuntu 14.04.2 Kernel: 3.13.0-53
contents of /etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
ifconfig -a:
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2115 errors:0 dropped:0 overruns:0 frame:0
TX packets:2115 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:151791 (151.7 KB) TX bytes:151791 (151.7 KB)
lspci -v:
00:00.0 Host bridge: Intel Corporation Device 5904 (rev 02)
Subsystem: Intel Corporation Device 2068
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=10 <?>
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at db000000 (64-bit, non-prefetchable) [size=16M]
Memory at 90000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] #1b
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] #13
00:08.0 System peripheral: Intel Corporation Device 1911
Memory at dc24f000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [dc] Power Management version 2
Capabilities: [f0] PCI Advanced Features
00:14.0 USB controller: Intel Corporation Device 9d2f (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 136
Memory at dc230000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller: Intel Corporation Device 9d31 (rev 21)
Memory at dc24e000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
00:16.0 Communication controller: Intel Corporation Device 9d3a (rev 21)
Memory at dc24d000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [8c] MSI: Enable- Count=1/1 Maskable- 64bit+
00:17.0 SATA controller: Intel Corporation Device 9d03 (rev 21) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 138
Memory at dc248000 (32-bit, non-prefetchable) [size=8K]
Memory at dc24c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at dc24b000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Device 9d10 (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=39, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: c4000000-da0fffff
Prefetchable memory behind bridge: 00000000a0000000-00000000c1ffffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [90] Subsystem: Intel Corporation Device 2068
Capabilities: [a0] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Access Control Services
Capabilities: [220] #19
Kernel driver in use: pcieport
00:1c.5 PCI bridge: Intel Corporation Device 9d15 (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=3a, subordinate=3a, sec-latency=0
Memory behind bridge: dc100000-dc1fffff
Capabilities: [200] L1 PM Substates
00:1c.7 PCI bridge: Intel Corporation Device 9d17 (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=3b, subordinate=3b, sec-latency=0
Memory behind bridge: dc000000-dc0fffff
00:1f.0 ISA bridge: Intel Corporation Device 9d4e (rev 21)
00:1f.2 Memory controller: Intel Corporation Device 9d21 (rev 21)
Memory at dc244000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 Audio device: Intel Corporation Device 9d71 (rev 21) (prog-if 80)
Flags: bus master, fast devsel, latency 32, IRQ 11
Memory at dc240000 (64-bit, non-prefetchable) [size=16K]
Memory at dc220000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
00:1f.4 SMBus: Intel Corporation Device 9d23 (rev 21)
Flags: medium devsel, IRQ 11
Memory at dc24a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
00:1f.6 Ethernet controller: Intel Corporation Device 15d8 (rev 21)
Memory at dc200000 (32-bit, non-prefetchable) [size=128K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [e0] PCI Advanced Features
3a:00.0 Network controller: Intel Corporation Device 24fd (rev 78)
Subsystem: Intel Corporation Device 9010
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at dc100000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 28-c6-3f-ff-ff-ae-5c-31
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
3b:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 137
Memory at dc000000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-00-00-01-00-4c-e0-00
Kernel driver in use: rtsx_pci
I'm assuming that this is a driver issue, but I'm not sure how to resolve. The device cannot connect via wireless and cannot use Network Manager.
Thanks in advance!
