Some days ago i bought a NUC7i3BNK and installed Ubuntu 16.04.02 with Kernel 4.8. Bluetooth does not work. My knowledge is not so deep, but I would say the driver is missing. Does anyone have a solution?
dmesg | grep Blue
[    3.000117] Bluetooth: Core ver 2.21
[    3.000130] Bluetooth: HCI device and connection manager initialized
[    3.000132] Bluetooth: HCI socket layer initialized
[    3.000134] Bluetooth: L2CAP socket layer initialized
[    3.000139] Bluetooth: SCO socket layer initialized
[    3.013961] Bluetooth: HCI UART driver ver 2.3
[    3.013962] Bluetooth: HCI UART protocol H4 registered
[    3.013963] Bluetooth: HCI UART protocol BCSP registered
[    3.013964] Bluetooth: HCI UART protocol LL registered
[    3.013964] Bluetooth: HCI UART protocol ATH3K registered
[    3.013965] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.013990] Bluetooth: HCI UART protocol Intel registered
[    3.014001] Bluetooth: HCI UART protocol BCM registered
[    3.014002] Bluetooth: HCI UART protocol QCA registered
[    3.014002] Bluetooth: HCI UART protocol AG6XX registered
[    3.061238] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[    3.077988] Bluetooth: hci0: Device revision is 16
[    3.077990] Bluetooth: hci0: Secure boot is enabled
[    3.077990] Bluetooth: hci0: OTP lock is enabled
[    3.077991] Bluetooth: hci0: API lock is enabled
[    3.077992] Bluetooth: hci0: Debug lock is disabled
[    3.077993] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.078594] Bluetooth: hci0: Failed to load Intel firmware file (-2)
[    3.357259] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[    3.358365] Bluetooth: hci0: Device revision is 16
[    3.358366] Bluetooth: hci0: Secure boot is enabled
[    3.358367] Bluetooth: hci0: OTP lock is enabled
[    3.358368] Bluetooth: hci0: API lock is enabled
[    3.358368] Bluetooth: hci0: Debug lock is disabled
[    3.358370] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.358394] Bluetooth: hci0: Failed to load Intel firmware file (-2)
[    3.486934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.486935] Bluetooth: BNEP filters: protocol multicast
[    3.486939] Bluetooth: BNEP socket layer initialized
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 004: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
The Nano Tranceiver is for my wireless keyboard and mouse. It makes no difference if I use another wireless keyboard:
Bus 001 Device 006: ID 24ae:2010
Roland
  • 41
The firmware for this BT device can be installed by updating linux-firmware package from yakkety repos.
It can be done by
sudo wget http://security.ubuntu.com/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.161.1_all.deb
sudo dpkg -i linux-firmware_1.161.1_all.deb
This firmware contains the required ibt-12-16.sfi file.
Most likely the xenial version will be updated too in a while.
Pilot6
  • 92,041
Downloaded missing device firmware ibt-12-16.sfi, copied to /lib/firmware/intel, reboot, works perfect.
It is wonderful to hear music with my bluetooth connected speakers again.
I am not a Linux expert. Could someone explain to me whether this is the right way?
Roland
  • 41
