I used to have Tweak-Tools but it was faulty and stopped working all the time. I didn't have unity-tweak-tool. I had the gnome-tweak-tool. So I removed the whole thing using purge when facing the problem below:
atenagm@atenagm-K46CB:~$ sudo apt-get install unity-tweak-tool
Reading package lists... Done
Building dependency tree
unity-tweak-tool : Depends: unity-webapps-common but it is not going to be installed
but even after that, I faced the same problem. I've also tried $sudo apt-get install -f and all other solutions found here but none of them worked.
I was thinking that maybe installing other desktop environments might be the cause. I once intalled gnome3 but the gui faced problems and I deleted all the dependencies. After restarting, problem had still remained, so I went for other environments like KDE. That solved the problem, though now I am still on unity desktop and no KDE desktop environment is running on the system. Might this be the problem? If so, how can I fix it and go back to the normal unity with all the functions such as unity-tweak-tool? and if not, how can I install unity-tweak-tool?
P.S. Here is the output of installing it using gdebi:
atenagm@atenagm-K46CB:~$ sudo gdebi unity-tweak-tool_0.0.7ubuntu2_all.deb
This package is uninstallable
Cannot install 'unity-webapps-common'
atenagm@atenagm-K46CB:~$ sudo gdebi unity-webapps-common_2.4.17+15.10.20150616-0ubuntu2_all.deb
Cannot install 'unity-webapps-service'
There is no error when performing $sudo apt-get update or $sudo apt-get check or any otherapt commands. The output of $sudo apt-get install -f is also as follows:
The following packages were automatically installed and are no longer required:
linux-headers-4.4.0-109 linux-headers-4.4.0-109-generic
linux-image-4.4.0-109-generic linux-image-extra-4.4.0-109-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Which I solved this issue also by performing an autoremove.
Update note: from chat with N0rbert we determined that main problem was
kubuntu-ppa/backports PPA. It messed Qt dependencies of unity-tweak-tool.
