Any body can help me? I want to install unity tweak tool but can't.
this is error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
unity-tweak-tool : Depends: unity-webapps-common but it is not going to be installed
Below is the output of apt-cache policy unity-tweak-tool:
$apt-cache policy unity-tweak-tool
unity-tweak-tool:
Installed: (none)
Candidate: 0.0.7ubuntu2
Version table:
0.0.7ubuntu2 500
500 ru.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
500 ru.archive.ubuntu.com/ubuntu xenial/universe i386 Packages 0.0.7-0~210~ubuntu16.04.1 500
500 ppa.launchpad.net/freyja-dev/unity-tweak-tool-daily/ubuntu xenial/main amd64 Packages
500 ppa.launchpad.net/freyja-dev/unity-tweak-tool-daily/ubuntu xenial/main i386 Packages
apt-cache policy unity-webapps-common unity-tweak-tool:
unity-webapps-common:
Installed: (none)
Candidate: 2.4.17+15.10.20150616-0ubuntu2
Version table:
2.4.17+15.10.20150616-0ubuntu2 500
500 http://ru.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
500 http://ru.archive.ubuntu.com/ubuntu xenial/main i386 Packages
unity-tweak-tool:
Installed: (none)
Version table:
0.0.7ubuntu2 500
500 http://ru.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
500 http://ru.archive.ubuntu.com/ubuntu xenial/universe i386 Packages
sudo apt-get update:
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease Hit:2 http://ru.archive.ubuntu.com/ubuntu xenial InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable Release
Hit:4 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:5 http://ru.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:7 http://ru.archive.ubuntu.com/ubuntu xenial-backports InRelease
Hit:8 http://ppa.launchpad.net/eiffelstudio-team/ppa/ubuntu xenial
sudo apt-get upgrade:
Reading package lists... Done Building dependency tree Reading
state information... Done Calculating upgrade... Done The following
packages were automatically installed and are no longer required:
accountsservice-ubuntu-schemas apparmor-easyprof
apparmor-easyprof-ubuntu click click-apparmor dbus-property-service
fonts-droid-fallback fonts-noto-mono gir1.2-accounts-1.0
gir1.2-click-0.4 gir1.2-gee-0.8 gir1.2-signon-1.0
indicator-bluetooth indicator-power libandroid-properties1
libboost-log1.58.0 libc-ares2 libclick-0.4-0 libdbus-cpp5
libdouble-conversion1v5 libfreerdp-cache1.1 libfreerdp-client1.1
libfreerdp-codec1.1 libfreerdp-common1.1.0 libfreerdp-core1.1
libfreerdp-crypto1.1 libfreerdp-gdi1.1 libfreerdp-locale1.1
libfreerdp-primitives1.1 libfreerdp-utils1.1 libgeonames0 libgflags2v5
libgoogle-glog0v5 libhardware2 libhybris libhybris-common1
libhybris-utils liblibertine1 liblttng-ust-ctl2 liblttng-ust0
libmedia1 libmysqlclient20 libnih-dbus1 libpkcs11-helper1
libprocess-cpp3 libqt4-declarative libqt4-network libqt4-script
libqt4-sql libqt4-sql-mysql libqt4-xml libqt4-xmlpatterns
libqt5positioning5 libqtcore4 libqtdbus4 libqtgui4 libsdl-image1.2
libsystemsettings1 libtrust-store2 libubuntu-app-launch2 liburcu4
libva-drm1 libva-x11-1 libvncclient1 libwhoopsie-preferences0
libwinpr-crt0.1 libwinpr-dsparse0.1 libwinpr-environment0.1
libwinpr-file0.1 libwinpr-handle0.1 libwinpr-heap0.1
libwinpr-input0.1 libwinpr-interlocked0.1 libwinpr-library0.1
libwinpr-path0.1 libwinpr-pool0.1 libwinpr-registry0.1
libwinpr-rpc0.1 libwinpr-sspi0.1 libwinpr-synch0.1
libwinpr-sysinfo0.1 libwinpr-thread0.1 libwinpr-utils0.1
libxcb-composite0 libxcb-xinerama0 network-manager-openvpn ofono
openvpn python3-apparmor python3-apparmor-click
python3-click-package python3-gnupg python3-libapparmor qtcore4-l10n
signon-ui-service suru-icon-theme system-image-common
system-image-dbus ubuntu-mobile-icons ubuntu-touch-sounds
ubuntuone-client-data ubuntuone-credentials-common unity-asset-pool
urfkill vlc-plugin-notify vlc-plugin-samba whoopsie-preferences Use
'sudo apt autoremove' to remove them. 0 to upgrade, 0 to newly
install, 0 to remove and 0 not to upgrade.
sudo apt-get install -f:
state information... Done The following packages were automatically
installed and are no longer required: accountsservice-ubuntu-schemas
apparmor-easyprof apparmor-easyprof-ubuntu click click-apparmor
dbus-property-service fonts-droid-fallback fonts-noto-mono
gir1.2-accounts-1.0 gir1.2-click-0.4 gir1.2-gee-0.8
gir1.2-signon-1.0 indicator-bluetooth indicator-power
libandroid-properties1 libboost-log1.58.0 libc-ares2 libclick-0.4-0
libdbus-cpp5 libdouble-conversion1v5 libfreerdp-cache1.1
libfreerdp-client1.1 libfreerdp-codec1.1 libfreerdp-common1.1.0
libfreerdp-core1.1 libfreerdp-crypto1.1 libfreerdp-gdi1.1
libfreerdp-locale1.1 libfreerdp-primitives1.1 libfreerdp-utils1.1
libgeonames0 libgflags2v5 libgoogle-glog0v5 libhardware2 libhybris
libhybris-common1 libhybris-utils liblibertine1 liblttng-ust-ctl2
liblttng-ust0 libmedia1 libmysqlclient20 libnih-dbus1
libpkcs11-helper1 libprocess-cpp3 libqt4-declarative libqt4-network
libqt4-script libqt4-sql libqt4-sql-mysql libqt4-xml
libqt4-xmlpatterns libqt5positioning5 libqtcore4 libqtdbus4 libqtgui4
libsdl-image1.2 libsystemsettings1 libtrust-store2
libubuntu-app-launch2 liburcu4 libva-drm1 libva-x11-1 libvncclient1
libwhoopsie-preferences0 libwinpr-crt0.1 libwinpr-dsparse0.1
libwinpr-environment0.1 libwinpr-file0.1 libwinpr-handle0.1
libwinpr-heap0.1 libwinpr-input0.1 libwinpr-interlocked0.1
libwinpr-library0.1 libwinpr-path0.1 libwinpr-pool0.1
libwinpr-registry0.1 libwinpr-rpc0.1 libwinpr-sspi0.1
libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1
libwinpr-utils0.1 libxcb-composite0 libxcb-xinerama0
network-manager-openvpn ofono openvpn python3-apparmor
python3-apparmor-click python3-click-package python3-gnupg
python3-libapparmor qtcore4-l10n signon-ui-service suru-icon-theme
system-image-common system-image-dbus ubuntu-mobile-icons
ubuntu-touch-sounds ubuntuone-client-data ubuntuone-credentials-common
unity-asset-pool urfkill vlc-plugin-notify vlc-plugin-samba
whoopsie-preferences Use 'sudo apt autoremove' to remove them. 0 to
upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
sudo apt-get install unity-tweak-tool:
state information... Done Some packages could not be installed. This
may mean that you have requested an impossible situation or if you are
using the unstable distribution that some required packages have not
yet been created or been moved out of Incoming. The following
The following packages have unmet dependencies. unity-tweak-tool :
Depends: unity-webapps-common but it is not going to be installed E:
grep -v ^# -r /etc/apt/sources.list /etc/apt/sources.list.d/*.list:
/etc/apt/sources.list:
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial main restricted
/etc/apt/sources.list:deb-src http://ru.archive.ubuntu.com/ubuntu/ xenial universe multiverse restricted main
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
/etc/apt/sources.list:deb-src http://ru.archive.ubuntu.com/ubuntu/ xenial-updates universe multiverse restricted main
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial universe
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial-updates universe
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial multiverse
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
/etc/apt/sources.list:deb http://ru.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
/etc/apt/sources.list:deb-src http://ru.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security main restricted
/etc/apt/sources.list:deb-src http://security.ubuntu.com/ubuntu xenial-security universe multiverse restricted main
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security universe
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu xenial-security multiverse
/etc/apt/sources.list.d/eiffelstudio-team-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/eiffelstudio-team/ppa/ubuntu xenial main
/etc/apt/sources.list.d/embrosyn-ubuntu-cinnamon-xenial.list:deb http://ppa.launchpad.net/embrosyn/cinnamon/ubuntu xenial main
/etc/apt/sources.list.d/fingerprint-ubuntu-fingerprint-gui-xenial.list:deb http://ppa.launchpad.net/fingerprint/fingerprint-gui/ubuntu xenial main
/etc/apt/sources.list.d/google-chrome.list:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/kubuntu-ppa-ubuntu-backports-xenial.list:deb http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu xenial main
/etc/apt/sources.list.d/mc3man-ubuntu-gstffmpeg-keep-xenial.list:deb http://ppa.launchpad.net/mc3man/gstffmpeg-keep/ubuntu xenial main
/etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list:deb http://ppa.launchpad.net/moka/daily/ubuntu xenial main
/etc/apt/sources.list.d/pasgui-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/pasgui/ppa/ubuntu xenial main
/etc/apt/sources.list.d/thomas-schiex-ubuntu-blender-xenial.list:deb http://ppa.launchpad.net/thomas-schiex/blender/ubuntu xenial main
/etc/apt/sources.list.d/webupd8team-ubuntu-atom-xenial.list:deb http://ppa.launchpad.net/webupd8team/atom/ubuntu xenial main
/etc/apt/sources.list.d/webupd8team-ubuntu-sublime-text-3-xenial.list:deb http://ppa.launchpad.net/webupd8team/sublime-text-3/ubuntu xenial main
