In the policy gradient method, there's a trick to reduce the variance of policy gradient. We use causality, and remove part of the sum over rewards so that only actions happened after the reward are taken into account (See here http://rail.eecs.berkeley.edu/deeprlcourse/static/slides/lec-5.pdf, slide 18).
Why does it work? I understand the intuitive explanation, but what's the rigorous proof of it? Can you point me to some papers?
nbro
  • 42,615
  • 119
  • 217
An important thing we're going to need is what is called the "Expected Grad-Log-Prob Lemma here" (proof included on that page), which says that (for any $t$):
$$\mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta}(a_t \mid s_t) \right] = 0.$$
Taking the analytical expression of the gradient (from, for example, slide 9) as a starting point:
$$\begin{aligned} \nabla_{\theta} J(\theta) &= \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \left( \sum_{t=1}^T \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \right) \left( \sum_{t=1}^T r(s_t, a_t) \right) \right] \\ % &= \sum_{t=1}^T \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=1}^T r(s_{t'}, a_{t'}) \right] \\ % &= \sum_{t=1}^T \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) + \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=t}^T r(s_{t'}, a_{t'}) \right] \\ % &= \sum_{t=1}^T \left( \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) \right] \\ + \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=t}^T r(s_{t'}, a_{t'}) \right] \right) \\ \end{aligned}$$
At the $t^{th}$ "iteration" of the outer sum, the random variables $ \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) $ and $ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) $ are independent (we assume, by definition, the action only depends on the most recent state), which means we are allowed to split the expectation:
$$\nabla_{\theta} J(\theta) = \sum_{t=1}^T \left( \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) \right] \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \right] \\ + \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=t}^T r(s_{t'}, a_{t'}) \right] \right)$$
The first expectation can now be replaced by $0$ due to the lemma mentioned at the top of the post:
$$ \begin{aligned} \nabla_{\theta} J(\theta) % &= \sum_{t=1}^T \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \left[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \sum_{t'=t}^T r(s_{t'}, a_{t'}) \right] \\ % &= \mathbb{E}_{\tau \sim \pi_{\theta}(\tau)} \sum_{t=1}^T \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \left( \sum_{t'=t}^T r(s_{t'}, a_{t'}) \right). \\ \end{aligned} $$
The expression on slide 18 of the linked slides is an unbiased, sample-based estimator of this gradient:
$$\nabla_{\theta} J(\theta) \approx \frac{1}{N} \sum_{i=1}^N \sum_{t=1}^T \nabla_{\theta} \log \pi_{\theta} (a_{i, t} \mid s_{i, t}) \left( \sum_{t'=t}^T r(s_{i, t'}, a_{i, t'}) \right)$$
For a more formal treatment of the claim that we can pull $\sum_{t'=1}^{t-1} r(s_{t'}, a_{t'})$ out of an expectation due to the Markov property, see this page: https://spinningup.openai.com/en/latest/spinningup/extra_pg_proof1.html
Misha
  • 103
Dennis Soemers
  • 10,519
  • 29
  • 70
A correct proof is given at https://spinningup.openai.com/en/latest/spinningup/extra_pg_proof1.html. It uses, among other techniques, the probability chain rule.
On the contrary, an attempt to prove "reward to go" by applying $ X, Y \: independent \implies E[XY] = E[X]E[Y]$ does not work.
The random variables $ \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) $ and $ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) $ are generally not independent. They would be independent, if $ P[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) \mid \sum_{t'=1}^{t-1} r(s_{t'}, a_{t'}) ] = P[ \nabla_{\theta} \log \pi_{\theta} (a_t \mid s_t) ] $ but this does not follow from $ \pi_{\theta}(a_t \mid s_t) = \pi_{\theta}(a_t \mid s_t, s_{t-1},...,s_1,a_{t-1}, ..., a_1) $
Consider the following setup as an example for the dependency between the two random variables in question.
times = {1, 2, 3, ..., T}
states = {1, 2, 3, ..., T}
actions = {0, 1}
$ \pi(a_t = 0 \mid s_t) = \frac{1}{s_t} $
$ r(s_t, a_t) = 1 $ i.e. the event reward at time t equals 1 and the total reward from time 1 to time t-1 equals t-1
$ P(s_1 = 1) = 1 $ i.e. all trajectories start in state 1
$ P(s_{t+1} = s_t + 1 \mid s_t, a_t) = 1 $ i.e. the next state, given the current state and the current action, is always the current state + 1
As a result, the higher time $ t $, the higher the state $ s_t $, the higher the probability for action $ a_t = 1 $ and the higher the total reward from time $ 0 $ to time $ t-1 $, i.e. the values of $ \pi(a_t \mid s_t) $ and thus the values of $ \nabla_{\theta} \log \pi (a_t \mid s_t) $ are highly correlated with the total rewards from time $ 0 $ to time $ t-1 $, hence respective random variables are not independent of each other.
blubb3456
By linearity of expection and using the distributive property:
$$\begin{align} \nabla_{\boldsymbol{\theta}} J(\boldsymbol{\theta}) &= \mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \left( \sum_{t=1}^T \nabla_{\theta} \log \pi_{\theta} (\mathbf{a}_t \mid \mathbf{s}_t) \right) \left( \sum_{t=1}^T r(\mathbf{s}_{t}, \mathbf{a}_{t}) \right) \right] \\ &= \sum_{t=1}^T \mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\theta} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \sum_{t'=1}^T r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] \\ &= \sum_{t=1}^T \mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\theta} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \sum_{t'=1}^{t-1} r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) +\nabla_{\theta} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \sum_{t'=t}^T r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] \\ & = \sum_{t=1}^T \sum_{t'=1}^{t-1}\mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \, r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] +\sum_{t=1}^T \mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\sum_{t'=t}^T r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right]\\ \end{align}$$
and the first term can be further expanded as follows:
$$\begin{align} &\sum_{t=1}^T \sum_{t'=1}^{t-1}\mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \, r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] \\ = &\sum_{t=1}^T \sum_{t'=1}^{t-1} \mathbb{E}_{(\mathbf{s}_{t}, \mathbf{a}_{t}, \mathbf{s}_{t'}, \mathbf{a}_{t'}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t}, \mathbf{a}_{t}, \mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \, r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] \\ = &\sum_{t=1}^T \sum_{t'=1}^{t-1} \mathbb{E}_{(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[\mathbb{E}_{(\mathbf{s}_{t}, \mathbf{a}_{t}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t}, \mathbf{a}_{t} \mid \mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \, r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] \right] \\ = &\sum_{t=1}^T \sum_{t'=1}^{t-1} \mathbb{E}_{(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[ r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \; \mathbb{E}_{(\mathbf{s}_{t}, \mathbf{a}_{t}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t}, \mathbf{a}_{t} \mid \mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\right] \right] \\ \end{align} $$
The innermost expectation can be broken down further into $$\mathbb{E}_{(\mathbf{s}_{t}, \mathbf{a}_{t}) \sim p_{\boldsymbol{\theta}}(\mathbf{s}_{t}, \mathbf{a}_{t} \mid \mathbf{s}_{t'}, \mathbf{a}_{t'})} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \right]\\ = \int \int \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\pi_{\boldsymbol{\theta}}(\mathbf{a}_t \mid \mathbf{s}_t) \, \, p(\mathbf{s}_{t} \mid \mathbf{s}_{t'}, \mathbf{a}_{t'})\, d\mathbf{a}_t \; d \mathbf{s}_t \\ = \int p(\mathbf{s}_{t} \mid \mathbf{s}_{t'}, \mathbf{a}_{t'}) \int \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\pi_{\boldsymbol{\theta}}(\mathbf{a}_t \mid \mathbf{s}_t) \, d\mathbf{a}_t \; d \mathbf{s}_t$$
where $ \int \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\pi_{\boldsymbol{\theta}}(\mathbf{a}_t \mid \mathbf{s}_t) \, d\mathbf{a}_t = \mathbb{E}_{ \mathbf{a}_{t} \sim \pi_{\boldsymbol{\theta}}( \mathbf{a}_{t} \mid \mathbf{s}_{t})} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \right] =0$ due to the EGLP lemma
As a result, we have $$\nabla_{\boldsymbol{\theta}} J(\boldsymbol{\theta}) = \sum_{t=1}^T \mathbb{E}_{\tau \sim p_{\boldsymbol{\theta}}(\tau)} \left[ \nabla_{\boldsymbol{\theta}} \log \pi_{\boldsymbol{\theta}} (\mathbf{a}_t \mid \mathbf{s}_t) \,\sum_{t'=t}^T r(\mathbf{s}_{t'}, \mathbf{a}_{t'}) \right] $$
