Is there an accepted order in which "List of"s should appear in the document?
For example, I have a section dedicated to "List of (Code) Listings", another for "List of Figures", and another for "List of Symbols". Is there a preferred order in which these should appear in the document?
David Poxon
  • 121
No.
But you can look at other books and see if there is a common pattern.
I would put them either alphabetically or else by size or perhaps importance. But put all the lists together in the TOC not interspersed with other things.
-1
In academic writing, lists should appear at the end of the document, just before any appendices.
In fiction, a single list of characters might appear after the table of contents and before the first chapter. Additional lists appear at the end of the tale or volume.
Hope this helps.
-1
The only rule I have seen is do not make "List of One Thing" where your list (and sub-list) only have one componant. If you have Item A.1 then you must have an A.2.
hszmv
  • 13,474
  • 30
