i am having a problem with the new gor upgrade. i do too much work online to allow moving of the vertical scroll bar (off of the right border).
is there some way to turn that aspect off?? i will not upgrade with that item in place. thanks
incidently, not sure how to contact torproject with questions. the result of a chat attempt looks like:
TOR CHAT NA
[15:54] qwebirc v0.92 [15:54] Copyright (C) 2008-2012 Chris Porter and the qwebirc project. [15:54] http://www.qwebirc.org [15:54] Licensed under the GNU General Public License, Version 2. [15:54] == ERROR: Anonymous TOR usage is unavailable
pardon, i do not see a list of tags to choose from. tag?: new version, user setting PREFS, dead in the water / cannot use? configuration? maybe you can add a drop down box of tags?
This new feature is called, "Letterboxing"
Tor Browser, in its default mode, is starting with a content window rounded to a multiple of 200px x 100px to prevent fingerprinting the screen dimensions. The strategy here is to put all users in a couple of buckets to make it harder to single them out. That worked until users started to resize their windows (e.g. by maximizing them or going into fullscreen mode). Tor Browser 9 ships with a fingerprinting defense for those scenarios as well, which is called Letterboxing, a technique developed by Mozilla and presented earlier this year. It works by adding white margins to a browser window so that the window is as close as possible to the desired size while users are still in a couple of screen size buckets that prevent singling them out with the help of screen dimensions.
If you don't want to use it, that's fine. Just be aware that using Tor Browser in fullscreen mode can help fingerprint you as a user.
How do you disable it?
go to about:config
change the privacy.resistFingerprinting.letterboxing to false.
How do you contact Tor Projects?
Links to the mailing lists and the IRC chat rooms are here: https://www.torproject.org/contact/
elmerjfudd
  • 2,284
  • 18
