Qiskit currently supports measurements in the computational basis from Qiskit Terra and Aer, that is, returning 1 if the qubit is in state $|1\rangle$, and 0 if the qubit is measured to be in state $|0\rangle$.
However, it is relatively easy to perform a change of basis unitary to our quantum circuit just prior to measurement, in order to instead measure in the eigenbasis of an arbitrary operator $A$:
First, we need to compute the eigendecomposition of our Hermitian observable $A|v_i\rangle=\lambda_i|v_i\rangle$.
Since $A$ is Hermitian, we are always able to diagonalize $A$ in this eigenbasis:
$$A = \sum_{i}\lambda_i |v_i\rangle \langle v_i|= U^\dagger \Lambda U$$
where $\Lambda = \text{diag}(\lambda_1,\dots,\lambda_n)$ and $U$ is a unitary matrix composed of the eigenvectors down the columns.
Next, we apply the unitary operation $U$ to the end of our quantum circuit, using qc.unitary.
To see why, note that $$\langle\psi|A|\psi\rangle = \langle\psi|U^\dagger \Lambda U|\psi\rangle = \langle\psi'|\Lambda|\psi'\rangle $$ where $|\psi'\rangle = U|\psi\rangle.$ Since $\Lambda$ is diagonal, we have transformed the problem from one where we must perform a measurement in an arbitrary basis, to one where we simply measure in the computational basis.
Finally, we measure the state $|\psi'\rangle$ in the computational basis $|i \rangle$ using qc.measure(q, c), and execute the jobs to get the counts and probabilities $\mathbb{P}_i = |\langle i|\psi'\rangle|^2$. Using the previously computed eigenvalues of $A$, we can now reconstruct the expectation value:
$$\langle \psi | A | \psi\rangle = \langle\psi'|\Lambda|\psi'\rangle = \sum_i \langle\psi'|i\rangle \langle i | \Lambda | i\rangle \langle i|\psi'\rangle = \sum_i \lambda_i \mathbb{P}_i$$
For example,
shots = result.results[0].shots
counts = result.get_counts()
probs = sorted([(i, c/shots) for i, c in counts.items()])
P = np.float64(np.array(probs)[:, 1])
A_expectation = lambda @ p
For a more high-level interface to coding and running variational quantum algorithms, you can also check out the PennyLane Python library, which has a Qiskit plugin available for using Qiskit simulators and IBM hardware as a backend.
For example, a expectation values of arbitrary operators in PennyLane using qiskit looks like this:
import pennylane as qml
dev = qml.device('qiskit.basicaer', wires=2)
use 'qiskit.ibm' instead to run on hardware
@qml.qnode(dev)
def circuit(x, y, z):
qml.RX(x, wires=0)
qml.RY(y, wires=1)
qml.RZ(z, wires=0)
qml.CNOT(wires=[0, 1])
return qml.expval(qml.Hermitian(A, wires=[0, 1]))
def cost(x, y, z):
return (1-circuit(x, y, z))**2
optimization follows
You can use NumPy, TensorFlow, or PyTorch to do the optimization - check out some of the tutorials.
Disclaimer: I am one of the developers on PennyLane.
