In Devitt et al. 2013's introduction to quantum error correction, the authors mention (bottom of page 12) how the stabilizer group for $N$ qubits is abelian.
More specifically, here is the quote:
An $N$-qubit stabilizer state $\lvert\psi\rangle_N$ is then defined by the $N$ generators of an Abelian (all elements commute) subgroup $\mathcal G$ of the $N$-qubit Pauli group, $$\mathcal G=\{K^i\,|\,K^i\lvert\psi\rangle=\lvert\psi\rangle,\,[K^i,K^j]=0,\forall (i,j)\}\subset \mathcal P_N.$$
I am confused by this. Is the stabilizer subgroup $\mathcal G$ defined as an abelian subgroup of elements of $\mathcal P_N$ that stabilizes $\lvert\psi\rangle$, or is it instead the case that the subgroup of elements of $\mathcal P_N$ that stabilize $\lvert\psi\rangle$ is abelian?
If the latter, doesn't this introduce ambiguity in the definition? There could be other elements that stabilize $\lvert\psi\rangle$ but not commute with $\mathcal G$.
If the former, how is this shown? I can see why the action of $K^i K^j$ and $K^j K^i$ is identical on $\lvert\psi\rangle$, but how do you show that $K^i=K^j$?
glS
  • 27,510
  • 37
  • 125
It is not necessary to define the group as commuting —$\def\ket#1{\lvert#1\rangle}$ by virtue of every element in the group stabilising the state $\ket{\psi}$, this property follows.
Because we are considering subgroups of the $N$-qubit Pauli group, any two elements either commute or anti-commute. Let $P \in \mathcal P_N$ be an operator which stabilises some vector $\ket{\psi}$, that is such that $P \ket{\psi} = \ket{\psi}$. Suppose that $Q$ anticommutes with $P$. It then follows that $$ Q \ket{\psi} = Q P \ket{\psi} = - P Q \ket{\psi}. $$ Now, if $Q \ket{\psi} = \lambda_Q \ket{\psi}$ for any scalar $\lambda_Q$ at all, we have $$ \lambda_Q \ket{\psi} = - P Q\ket{\psi} = - \lambda_Q \ket{\psi}. $$ But this implies that either $\lambda_Q = 0$ (which is impossible as $Q$ is unitary) or $\ket{\psi} = \mathbf 0$, the zero vector.
It follows that if $\ket{\psi}$ is actually a state (so that in particular it has norm 1), any operator in $\mathcal P_N$ which has $\ket{\psi}$ as a $\pm1$ eigenvector must commute with all operators which stabilise $\ket{\psi}$. Thus the subgroup of $\mathcal P_N$ which stabilises $\ket{\psi}$ is abelian.
Niel de Beaudrap
  • 12,522
  • 33
  • 73
