I read about the stabilizer code as a set characterized by elements stabilized by an abelian group, i.e one whose elements commute.
I can imagine that requiring commutation helps to define new codes starting from classical linear codes.
However I don't see why I often read about that as a necessary condition, when common codes (e.g. the Shor code) doesn't satisfy it.
Adam Zalcman
  • 25,260
  • 40
  • 95
Daniele Cuomo
  • 2,068
  • 25
We do not require stabilizers to commute. We require them to jointly stabilize a non-trivial subspace. As a consequence, they commute.
Suppose $P$ and $Q$ are anti-commuting $n$-qubit Pauli operators which jointly stabilize a subspace $C$ of the $n$-qubit Hilbert space. Let $|\psi\rangle\in C$. Then $P|\psi\rangle=|\psi\rangle$ and $Q|\psi\rangle=|\psi\rangle$, so
$$ PQ|\psi\rangle=|\psi\rangle.\tag1 $$
However, $PQ=-QP$, so
$$ PQ|\psi\rangle=-QP|\psi\rangle=-|\psi\rangle.\tag2 $$
Combining $(1)$ and $(2)$ we have $|\psi\rangle=-|\psi\rangle$ so $|\psi\rangle = 0$. Therefore, $C$ is trivial.
Thus, we see that non-abelian subgroups of the Pauli group stabilize the trivial subspace. Consequently, the stabilizer group of any quantum error correcting code is abelian.
In particular, stabilizer generators of the Shor's 9-qubit code, e.g.
$$ \begin{align} g_1&=ZZIIIIIII\\ g_2&=IZZIIIIII\\ g_3&=IIIZZIIII\\ g_4&=IIIIZZIII\\ g_5&=IIIIIIZZI\\ g_6&=IIIIIIIZZ\\ g_7&=XXXXXXIII\\ g_8&=IIIXXXXXX \end{align}\tag3 $$
clearly commute pairwise and thus generate an abelian group.
Adam Zalcman
  • 25,260
  • 40
  • 95
