There are many posts to this question from Nielson and Chuang's Quantum Computation and Quantum Information Exercise 1.2 page 57. It is required to prove that if a hypothetical device exists, which could distinguish between two non-orthogonal quantum states $|\psi\rangle$ or $|\phi\rangle$ and correctly output the answer, we could create a device that cloned the states $|\psi\rangle$ and $|\phi\rangle$ , contradicting the no-cloning theorem.
I propose an algorithm that will clone any state.
  1. Take $|\psi\rangle$ and $|\psi'\rangle$ as basis, with $|\psi'\rangle$ being orthogonal to $|\psi\rangle$ .
  2. Measure a new qubit with this basis.
  3. If the result is $|\psi\rangle$ , then we are done. If the result is $|\psi'\rangle$ , then use the X gate to get $|\psi\rangle$ as the result.
  4. Repeat this for all other qubits taking those qubits and their orthogonal qubit as the basis.
I suspect that changing the basis is a problem, but I am not able to pinpoint what exactly is the problem. I am quite new to quantum computing and even anything quantum in general. So, I require easy-to-understand explanations.
In other answers, cloning $|\psi\rangle$ is considered trivial if we identify which one of the qubits is $|\psi\rangle$ . But this is not trivial to me, we only know that this qubit is $|\psi\rangle$ and not $|\phi\rangle$ but we didn't know the states of $|\psi\rangle$ and $|\phi\rangle$ from the beginning. We only know that out of two unknown non-orthogonal states, our test qubit is $|\psi\rangle$ , and $|\phi\rangle$ is the other one. So how can we clone a qubit if nothing is known about it?
Frederik vom Ende
  • 4,163
  • 49
The crucial point about the no-cloning theorem is (as you already suspect) the basis choice.
You can always find a specific cloning machine for a specific basis, but you cannot find a general cloning machine that accepts any state and clones it.
This is probably best understood via examples and this topic has been discussed before. Please have a look here or here.
Edit: a simple example
The simplest version of the argument that I know of is this:
Let's say you have a machine $M$ that is able to clone the states $|0\rangle$ and $|1\rangle$. This could be written like this:
$$|0\rangle \overset{M}{\to} |0\rangle |0\rangle$$ $$|1\rangle \overset{M}{\to} |1\rangle |1\rangle$$
This mapping property fully determines how that machines acts on the state $|+\rangle = \frac{1}{\sqrt 2} (|0\rangle + |1\rangle)$ due to the linearity of quantum mechanics:
$$|+\rangle = \frac{1}{\sqrt 2} (|0\rangle + |1\rangle) \overset{M}{\to} \frac{1}{\sqrt 2}(|0\rangle |0\rangle + |1\rangle |1\rangle) \neq |+\rangle |+\rangle$$
So, the machine fails to clone the $|+\rangle$ state. In fact, it will fail to clone any state other than $|0\rangle$ or $|1\rangle$.
To conclude, you can define a machine that is able to clone states of a given basis. But by that choice you restrict that machine from cloning any other states.
qubitzer
  • 934
I think what you asking about is the following setting: you are given a qubit which is either $|\psi\rangle$ or $|\psi'\rangle$ with are not orthogonal. You know what those two possible states are, but not which it is. You have to clone it.
You start by measuring in a basis that prijects onto $|\psi\rangle$. If you get the other answer, you know you did not have $|\psi\rangle$, so you produce multiple copies of $|\psi'\rangle$. That part is no problem.
The problem is what happens if you get the answer corresponding to $|\psi\rangle$? Since $|\psi\rangle$ and $|\psi'\rangle$ are not orthogonal, there's some chance that the original state was $|\psi'\rangle$, you simply don't know. Even worse, now, whatever the state was initially, it's $|\psi\rangle$. So all information about what the state was has been lost. You cannot tell what the state was, and you have no hope to clone it.
DaftWullie
  • 62,671
  • 55
  • 140
