For $[n,k]$ stabilizer code, we can prepare an encoded state by simply measuring an initial state $|0\rangle^{\otimes n}$ with the stabilizers $g_1, \dots ,g_{n-k}$ and fixing it according to the measurement result. However, this does not apply to encoding an unknown state $|\psi\rangle \in \mathcal{H}^{\otimes k}$.
Is there any systematic way to perform such encoding?
hft
  • 903
  • 13
Jiawei Wu
Encoding circuits exist for all stabilizer codes. You can find a procedure to construct them in literature [1,2].
I previously outlined this procedure, with a worked out example for the Steane code.
[1] D. Gottesman, Stabilizer Codes and Quantum Error Correction, arXiv:quant-ph/9705052.
[2] Gaitan, Frank, Quantum Error Correction and Fault Tolerant Quantum Computing (CRC Press, 2008).
Abdullah Khalid
  • 1,933
  • 17
Basically, think of any circuit between two qubits that you might want to apply. In this case, a SWAP where one of the qubits is prepared in $|0\rangle$. (This is implemented by two controlled-nots, the first one controlled off the unknown qubit state, the second targeting the unknown state.) Then, all you have to do is consider one of the qubits as a normal qubit, with normal gates, and the second qubit as a logical qubit, i.e. encoded in an error correcting code, and the gates you apply are the logical gates. It'll work exactly as you expect (provided there are no errors in the circuit).
DaftWullie
  • 62,671
  • 55
  • 140
