  1. What is meant by a local Lagrangian density?
  2. How will a non-local Lagrangian look like?
  3. What is the problem that we do not consider such Lagrangian densities?
SRS
  • 27,790
  • 13
  • 115
  • 365
What is a local Lagrangian density?
A classical field theory on Minkowski space $\mathbb R^{d,1}$ is specified by a space $\mathcal C$ of field configurations $\phi:\mathbb R^{d,1}\to T$, and an action functional $S:\mathcal C\to\mathbb R$. The set $T$ is called the target space of the theory, and is often a vector space. If there exists a function $L:\mathcal C\times\mathbb R\to \mathbb R$ for which \begin{align} S[\phi] = \int_{\mathbb R} dt\, L[\phi](t), \end{align} then we call $L$ a lagrangian for the theory. If, further, there exists a function $\tilde L$ such that \begin{align} L[\phi](t) = \int_{\mathbb R^d} d^d\mathbf x \,\tilde L[\phi](t, \mathbf x) \end{align} then we call $\tilde L$ a langrangian density for the theory. Finally, if there exists a positive integer $n$ and a function $\mathscr L$ such that \begin{align} \tilde L[\phi](t, \mathbf x) = \mathscr L(t,\mathbf x,\phi(t, \mathbf x), \partial\phi(t,\mathbf x), \dots, \partial^n\phi(t,\mathbf x)) \end{align} then we say that the lagrangian density is local. In other words, the lagrangian density is local provided its value at a given spacetime point depends only on that point, the value of the field at that point, and a finite number of its derivatives at that same point.
An example of a non-local Lagrangian density.
Consider $T = \mathbb R$, namely a theory of a single real scalar field. Let $\mathbf a\in\mathbb R^d$ be given, and define a Lagrangian density by \begin{align} \tilde L[\phi](t,\mathbf x) = \phi(t,\mathbf x) + \phi(t, \mathbf x+\mathbf a). \end{align} This Lagrangian density is not local because the value of the Lagrangian at a given point $(t,\mathbf x)$ depends on the value of the field at that point and on the value of the field at the point $(t,\mathbf x+\mathbf a)$. If we were to Taylor expand the second term $\phi(t,\mathbf a)$ about $\mathbf x$, then we would see that the Lagrangian density depends on an infinite number of derivatives of the field, thus violating the definition of a local Lagrangian density.
What's the issue with theories with non-local Lagrangian densities?
I'm no expert on this, so I'll divert to another user. I will say, however, that people do study theories with non-local Lagrangian densities in practice, so there's nothing a priori "wrong" with them, but they might generically exhibit some pathology that you might prefer not to have.
Perhaps most relevant, though, if you're taking QFT from a high energy theorist, for example, is that the Lagrangian density of the Standard Model is local, so there's no need to consider non-local beasts if one is studying the Standard Model.
SRS
  • 27,790
  • 13
  • 115
  • 365
joshphysics
  • 58,991
