I've been reading through Matthew Schwartz's book "Quantum Field Theory and the Standard Model" and in chapter 24 there is a section on locality (section 24.4). In it he defines locality in terms of the Lagrangian stating
" We take locality to mean that the Lagrangian is an integral over a Lagrangian density that is a functional of fields and their derivatives evaluated at the same point."
Which is all well and good, but then he further elaborates to say that
"To be clear, this definition is mathematical, not physical: it is a property of our calculational framework, not of observables."
This part confuses me as I thought that the whole motivation was physical, i.e. that objects at different spacetime points should not be able to directly interact with one another? It makes sense to me that, as the Lagrangian density characterises the dynamics of a physical system at a given spacetime point, and locality demands that the dynamics of the system at that given point should depend only on the state of the system at that point (i.e. the field configuration and how it's changing at that point), then clearly the Lagrangian density should depend on no more than the state of the system at that point, i.e. the field configuration and its rate of change (in spacetime)?! Maybe I'm missing something?
Will
  • 3,163
For a classical field theory or a classical field and particle theory you want the dynamics of that stationary path. (Or the dynamics of one of the stationary paths.) But you consider all kinds of dynamics, and just reject the ones that don't have a stationary action.
If you know the Euler-Lagrange equations you are aiming for are going to just have/be derivatives at points, it makes sense to start with that, because it makes it easier to get that.
For a quantum field theory, you have to sit back and ask what the observables you are aiming for are. One possibility is that you are computing a scattering matrix. In which case your observables in a sense could be on shell free particle states.
If you want to think about it as a distinction between on shell and off shell interactions that might be what you are aiming for.
Off shell interactions are not what you are looking for as part of your observables. So they are purely about the math you are using to describe relationships between on shell states.
So it might not seem a big deal whether your density is written in terms of derivatives of the field or not. What matters is whether you included all the right on shell states and properly got the relationships between them.
There isn't a location to an on shell state, they are separated more in the sense of being approximately free than in having approximate locations that don't overlap. But the physical distinction and observables is likely the on shell states and their relationships. The mathematics is just how you compute them. So locality could be about how you compute the relationships. And so aiming for local or nonlocal might not be the key compared to having the right on shell states and relationships between them.
I couldn't read page 475 so I could be totally wrong about what the author intended.
Timaeus
  • 26,055
  • 36
  • 71
