13
When we spin a coin on a table, we observe 2 things:
  1. It slows down and stops after sometime.
  2. It does not stay at just one point on the table but its point of contact with table changes with time.
I was trying to explain quantitatively this but I am stuck at how to take frictional torques into account. Any help will be appreciated.
Sahil Chadha
  • 2,833
I think that if you spin "perfectly" (i.e., such that the rotational axis is normal to the surface and goes through he centre of the coin), is only a rotation movement with friction. This motion is unstable though, so, the axis tilt a little bit and this cause a rotation in the axis itself, the precession. The point of contact will be moving with the precession, maybe you can calculate its position by geometrical arguments, although it should be a circular/spiral/cycloid movement (if you see in the coin a movement towards a given direction, this is solely because of the way you made if spin or the coin or because the table has a tilt or imperfections).
I don't know your level of knowledge, but for a complete description you need knowledge of Hamiltonian dynamics, rigid body and Euler angles, so basically a course of classical (a.k.a. analytical) mechanics. A very common, related, problem is the problem of the spinning top, the difference here is that the contact point is material, so there you have to see if you have to see if the contact point slips or not (if not, it creates a rotation in the axis normal to the coin).
Personally I think that it is a complicated but somehow treatable problem (with a lot of patience).
chuse
  • 336
if u consider an idealised case, with no friction and air resitance and the coin is a perfect circle that only a minute elementary part of it is touching the ground. then u can sinply treat it as a disc rotating about the diameter.
But ofcourse thats not what you asked for :P u want the general case where all the forces matter since thats what happens in real life.
well one way u can take is to consider any elementary pary at distance r from diameter and add an additional force -bv (since air resistance proportional to velocity of that point) and explain why it slows down.
But as to why it doesnt stay at the same place is because it is not a perfect circle nor is it a 2-D disc.. its a cylinder and its point of contact is not just a single point. and the friction coeff on the floor is not same everywhere causing a net translation.
Analytically when the coin is static the gravity makes it fall to one side. But when it is spinning and gravity pulls each point of contact towards Down and Inside the circle of rotation.
Here the inside pull component is cancelled out at high speed as each point of contact has it. This is verified as the axes of the coin is always tilted and rotates forming a cone.
When the speed reduces the inside force makes it bend slightly more than before effectively increasing the circumference of points of contact. This increases the time to cancel out inside force and slowly the coin falls down.
There is no easy way to model a spinning coin and calculate these observations. It slows down mostly because of air resistance and friction(here you must take velocity dependent friction-angular velocity in your case-) and it moves due to the combination of torque of gravity(a.k.a. precession) and friction. Velocity dependent frictions generally gives you non-linear differential equations which are often very hard to handle. When you write hamiltonian and canonical equations probably you will get some coupled non-linear partial differential equations which are worst combinations to solve.
Moreover, after it slows enough, contact point(on the coin) will start to move and after that time you should consider rolling friction.
maynak
  • 538
